Author Topic: (PICS) Oil Pressure Switch Help  (Read 1625 times)
bp1911
  • Member since Nov '06
« on: Jan 11, 2007, 03:44:07 PM »
1985 4Runner (manufactured in May)
My oil pressure gauge does not operate and I am trying to track down the problem. I ran through the FSM diagnostics for the actual gauge on the dash and it works so I went to replace the oil pressure sending unit and there in lies my issue.
Here is what is on the vehicle currently:
Notice the wire coming out of the unit it self
Its connection
Here is the Unit that is supposed to be the factory replacement unit but as you can see there is no wire and it has the male button type connection
What are your thoughts and suggestions?
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
Re: (PICS) Oil Pressure Switch Help
« Reply #1 on: Jan 11, 2007, 04:06:07 PM »
take the old sending unit out of the block and remove the rubber boot, should have the connection on it . If not you can make one with the proper size female wire connector, just make sure it slips on sending unit connection tightly then slip the boot back on.
Cracker
  • God, Corps, Country
« Reply #2 on: Jan 11, 2007, 06:01:41 PM »
When I switched senders on my 88 (for an SR5 cluster swap), the old sender also had a blade connector. The new one had the round connector like in your pic. I found that the old connector, had a slot in the side of it, so it could just be slid over the round head of the new sender. So the connector is now at a 90° angle compared to how it was on the old sender.
I'll see if I can snap a pic tomorrow, if you want.
Art
99 Taco
80 Hilux - 20/22R Hybrid, Dual Mikuni's, R151 trans, Budbuilt X-member
74 FJ40 "The Project"
bp1911 [OP]
« Reply #3 on: Jan 11, 2007, 07:12:33 PM »
CRACKER,
Sure that would be great
KYOTA
  • Wreckin Ball '09
« Reply #4 on: Jan 11, 2007, 07:23:02 PM »
have you looked under the boot to see what you have ?
bp1911 [OP]
« Reply #5 on: Jan 11, 2007, 07:25:31 PM »
KYOTA,
Not yet. I will get to it tomorrow AM. I hope you are right as that will make my life much easier. I will update this tomorrow and let you know what I find.
Thanks!!
Cracker
« Reply #6 on: Jan 12, 2007, 01:35:40 PM »
OK...Heres pics: (Sorry about the blurriness...damn camera was acting up...)
Pull the boot off and this is what you'll see
The end of the connector in the boot. You can see it will slide over the blade connector on the regular idiot light sender.
Also this, the side of the same connector:
It has a slot in one side.
The the round disc and pin slide down inside the connector, 90° to what you would expect.
hard to tell in this pic, but the connector "lays flat" across the top of the sending unit, parallel to the engine block.
It will look and feel odd, like it wont stay on, but it will. The boot will help keep it secured.
Toyota usually has a mentality of using common parts across models, to keep things simple and inexpensive.
Kinda odd, how they designed this one connector to be used on two different connections, yet its on a pigtail. Meaning basically, there is the extra connector 6 inches upstream away from the sender. just kinda odd...but I guess there is probably a good reason why they did it.
HTH
« Last Edit: Jan 12, 2007, 01:40:06 PM by Cracker »
Art
99 Taco
bp1911 [OP]
« Reply #7 on: Jan 13, 2007, 07:53:40 PM »
THANKS!
Just as you stated and showed.
I love this place!
Last post Feb 13, 2004, 12:30:59 AM
by 95TacoTruck
Last post Sep 13, 2005, 08:12:11 PM
by RustyToy
Last post Feb 09, 2006, 01:03:15 PM
by abnormaltoy
Last post May 10, 2006, 06:54:56 PM
by RCKSQRL
Last post Apr 12, 2012, 08:10:55 PM
by daniresch
