Quick Ques.
I need advice on pinion angles. I have an '82 4x4 Longbed. I have a 4.5" lift on it. Currently I have a single T-case with an L50 tranny, but before I am done with my build I will have a dual setup. I was wondering if with the duals and this much lift it would be wise to add axle shims to help with pinion angle. What shim degree would be sufficient?
I am not very good at welding yet and don't want to rotate spring perches. this sounds like a good solution for the time being.
Thanks, Daniel Z
