Author Topic: I think I finally really get it  (Read 2179 times)
snowplow
  • Male Posts: 257
  • Member since Aug '06
  • smoke tires not drugs
« on: Jan 02, 2007, 10:29:10 PM »
I was just studying the crawl ratio table and I think I just got it... So do I have it right by saying with a Dual Ultimate Crawler (2.28/4.7) I can have 5 forward gears and a reverse gear in Hi range (1/1), low range (2.28/1), another low range from the rear box (4.7/1), and a third and even lower range by engaging both boxes (2.28X4.7=10.71/1) Oooooooooooooooooooooooooo...   :bowdown:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: I think I finally really get it
« Reply #1 on: Jan 03, 2007, 09:07:20 AM »
:yesnod:
giving you in effect 15 forward  and 3 reverse  :eyebrow:
Fearofrunner
  • Male Posts: 620
  • Member since Dec '06
  • HOW AN 84 SHOULD LOOK
« Reply #2 on: Jan 03, 2007, 09:41:12 AM »
and if you have a Hilux, then your a mini semi  :stopit: Crawler gears would be  :thumbs: :yesnod:
skid
  • Turtle Points: 144
  • Male Posts: 295
  • Member since Oct '04
« Reply #3 on: Jan 03, 2007, 10:20:42 AM »
:yesnod:
sorry, you're missing a few.   4 gear ratios for t-cases, 5 from transmission  =20 forward,  4 reverse
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
snowplow [OP]
  • Male Posts: 257
« Reply #4 on: Jan 03, 2007, 12:02:14 PM »
Rad!
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #5 on: Jan 03, 2007, 01:57:42 PM »
then how many gears do i have with a w56 and 3 t-cases? all 2.28 for now, but 1 set of 4.7's to come
skid
  • Male Posts: 295
« Reply #6 on: Jan 03, 2007, 02:48:05 PM »
t case ratios  with stock gears       1:1
                                                2.28:1
                                 (2.28x2.28)5.2:1
                         (2.28x2.28x2.28)11.8
= 4 t-case ratios, =20 forward gears
tcase ratios with 1 4.7                1:1
                                              2.28:1
                                              4.7:1
                              (2.28x2.28)5.2:1
                              (2.28x4.7)10.7:1
                       (2.28x2.28x4.7)24.4:1
= 6 t case ratios, =30 forward gears
Seems like over kill when put that way.
Last post Jan 27, 2011, 04:38:26 AM
by Rocksurfer
Last post Oct 08, 2013, 02:49:27 PM
by T.Rex
Last post Jan 17, 2013, 08:12:39 PM
by 86sasturbo
Last post Nov 02, 2014, 10:12:13 PM
by Rocksurfer
Last post Aug 25, 2018, 12:48:27 PM
by fasterspider
