Nice work. If that outside face gets over 100*F, you've got some serious issues.
going to replace the sink tomorrow, getting rid of the old, dingy white sink with a stainless steel one that is deeper and cost $6 off craigsso... i am thinking, figure how to remove the plumbing, and then jsut yanking it out...... then put some caulking in around the edge, and drop i nthe new one? reconnect the plumbing and good?
it does have a garabe disposal, so i will need to figure out how to deal with that.... do i need to put soem caulking around the drain too?
why do you use plumbers putty, instead of silicon?
Because I was told to!
really not an option to lower the drain..... i would need to cut the wall, and then try and deal with soldering copper pipe..... not something i really want to deal with, nor do i have a torch anymore
omg that little sink is packed
Started by BigMike Project Research and Build-Ups
Started by AaronB RC Rock Crawler Tech
Started by bebe Rubicon
Started by sparkys83yota Welding Tech
Started by YotaRick New Member Check-In!
