0 Members and 9 Guests are viewing this topic.
any other thoughts on the concrete countertops, or about stuff on the wood ?
i am going to be mounting some shelves to the wood paneling in the living room.since it is wood paneling, how am i going to find the studs?i will be mounting those tracks with the little slits in them, that then have a metal triangle clip into them so i can tailor the height, with a board across. they will be at least 12" deep, and 36" long
Ya, attach a shop vac to the sander
clean, clean, clean, and more clean before you paint. When you think you've gotten all the dust, you haven't
On the range side the green should be the neutral lead. (but look up the manual online).
be careful when giving advice on electricity if you are not an electrician. that is an extremely false statement. the ground and nuet are VERY different
They mean flex conduit. Better call a electrician
Started by BigMike Project Research and Build-Ups
Started by AaronB RC Rock Crawler Tech
Started by bebe Rubicon
Started by sparkys83yota Welding Tech
Started by YotaRick New Member Check-In!
