Did the swap out over the weekend using Brandon's wiring info and it works great! A couple of the wire colors were different than what is listed, but I just used the connector numbers and everything works perfect! Had to run a new wire for the tach and I wound up connecting it directly to the back of the circuit board where the screw is because I couldn't find a source for the extra connector I needed for the plug. Good job, Brandon
I cut off the other end from the pnp long enough back so that it just plugged in making a factory looking connection. Your clip is easy though, nice..Boy that was a long time ago..
I've got a 1982 basic model and I've installed the SR5 cluster. I used the new pin-outs and everything is working except the tach. I've read through the threads and followed the instructions but without success. I know the gauges worked before. I've followed the back of the panel to the #14 screw for the tach, attached a wire there and then tried both the plugged end and the other wire as shown in some of the earlier photos. Any trouble shooting thoughts out there? Thanks.
my guess would be that they are different You need a wiring diagram..
Started by 94SRUNNER Toyota Pickup/4Runner Tech 1979-95
Started by Lonestar Honcho General 4WD Discussion
Started by T Pennington Toyota Pickup/4Runner Tech 1979-95
Started by jrock Toyota Pickup/4Runner Tech 1979-95
Started by Snapshot New Member Check-In!
