Yup, It had the ABS intergrated into the engine harness. It has an electronic speed sensor, with the ABS sensor on the rear diff still intact. There are 2 e-brake cables, and it has coils.
There is an additional brake line output on the Brake Master Cylinder, that runs to the RWAL power steering thing, then exits the power steering RWAL and runs back to the rear brake proportioning valve.
I think if I block off the additional master cylinder output, and block off the input for the ABS on the brake proportioning valve, It should work allright...What do you think?
Thanks,
Zac
