Author Topic: Transfercase Help.  (Read 1069 times)
rage
  • Turtle Points: 26
  • Male Posts: 142
  • Member since Jul '06
Transfercase Help.
« on: Dec 14, 2006, 01:41:24 PM »
my transfer case will not come out of 4low, and there is a bunch of play. i have tried while at a standstill, slow creep in both driections and with the hubs locked and unlocked. the problem is an an 87 carb22R. would a messed up tranny shifter do anything? is there any "easy" way to get it back into high range?
RRMike
  • Turtle Points: 2
  • Member since Dec '05
Re: Transfercase Help.
« Reply #1 on: Dec 14, 2006, 03:08:57 PM »
Pull the shifter and see if the shifter is out of the shift rods it rides in.  You can shift it manually with a screwdriver.  Do you have TC gears or have you had the case apart for anything?
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #2 on: Dec 15, 2006, 10:10:18 AM »
Can you pull "up" on the shifter?   :yikes:   (like almost an inch?)
If so, ya lost your clip that holds the shifter down and managed to get the shifter out of the rails.
rage [OP]
  • Turtle Points: 26
  • Male Posts: 142
« Reply #3 on: Dec 16, 2006, 11:22:37 AM »
i have never gone inside the case, and the gears are stock. the shifter kinda comes up 3/4" but springs back down. all of the play is where gears used to be, turned the "j" pattern into a triangle.
. i will pull it apart tomorrow and see.
Last post Apr 26, 2008, 02:28:26 PM
by johnny916
Last post Nov 16, 2009, 10:45:36 AM
by cgbemis
Last post Jan 09, 2010, 08:19:09 PM
by superyota
Last post Dec 20, 2010, 06:49:23 PM
by E YOTA
Last post Dec 06, 2010, 11:15:38 AM
by yotarunner85
