Author Topic: Finally, starting SAS  (Read 4818 times)
88runner
  • Turtle Points: 756
  • Member since May '03
  • Click me!
« on: Feb 07, 2004, 05:16:05 PM »
I finally got the swapping process started
the plan is to put rear spring in the front with a minimal drop front hanger, high steer, I'll put an update picture when it'll be done.  :flamer: :
« Last Edit: Feb 07, 2004, 05:22:16 PM by 88runner »
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
moutaintoys
  • Turtle Points: -63
  • Male Posts: 358
  • Member since Dec '03
Re:Finally, starting SAS
« Reply #1 on: Feb 07, 2004, 05:24:19 PM »
did this to o/l runner about 5 years ago need big spring lift or hight steer hits fram
Lets go break somethin "GO NAVY"
supercrawler
  • Turtle Points: 10
  • Male Posts: 139
  • Member since Feb '03
  • After it's all about "TOYOTA"
« Reply #2 on: Feb 08, 2004, 10:58:55 PM »
Welcome :biggthumpup:
So when do you think it'll be done?
Mine turn out like this.
supercrawler
  • Turtle Points: 10
  • Male Posts: 139
« Reply #3 on: Feb 08, 2004, 11:04:53 PM »
And this..
84runner
  • Turtle Points: 99
  • Member since Dec '02
« Reply #4 on: Feb 09, 2004, 12:46:20 AM »
Lookin good but time for the fun part!   Putting the grinder to use!
88runner [OP]
  • Click me!
« Reply #5 on: Feb 09, 2004, 01:34:23 PM »
When is it gona be done, I don't know, I'm really nut in a hurry on this project, the wheeling season only starts at end of march end some time in april.
The grinder got out of his box past weekend but i didn't had time to finish so both side are about 3/4 done.
88 4runner v6,
solid axle'd
donkeykong
  • Turtle Points: -159
  • Member since Jun '03
  • My truck and a nice trail...that's all I need
« Reply #6 on: Feb 09, 2004, 01:38:25 PM »
Are there any write ups on SAS.  My buddy just got a 88 22re and his first major upgrade will be a SAS.  I am going to be helping all the way through and any instructions or hints will help very much
« Last Edit: Feb 09, 2004, 01:38:46 PM by donkeykong »
88runner [OP]
  • Click me!
« Reply #7 on: Feb 09, 2004, 01:45:19 PM »
all-pro have insturctions and you will find lot of info searchin the web. I have a text file that explain it, I'll try to find it.
88 4runner v6,
solid axle'd
88runner [OP]
  • Click me!
« Reply #8 on: Feb 19, 2004, 08:04:52 AM »
OK, I've searched for this for a while now.
do anyone know de length and I.D. of the tube that goes in the frame?
I have the bushings but can't find them in my mess so someone please help me
88 4runner v6,
solid axle'd
84runner
  • Turtle Points: 99
« Reply #9 on: Feb 19, 2004, 10:17:45 AM »
have you tried calling All Pro?
NWyoat
  • Male Posts: 44
  • Member since Feb '04
  • shake'n bake
« Reply #10 on: Feb 19, 2004, 11:00:56 AM »
the hysteer wont work the drag link will hit the frame. all you need is crossover and a beefy tie rod
my half doors have beer holders.
88runner [OP]
  • Click me!
« Reply #11 on: Feb 19, 2004, 04:18:42 PM »
Why would the drag link on a High Steer hit the frame more then a crossover?
from what I've seen, crossover put the drag link higher then high steer, anyway i'll just see what go wrong. I have decided to go 1" drop on the hanger.
88 4runner v6,
solid axle'd
  • Turtle Points: 679
  • Don't blame me, I didn't vote for this crap.
« Reply #12 on: Feb 19, 2004, 06:07:32 PM »
I would think that All pro would use a factory size bushing.  I just measured a factory rubber bushing, it came in at 1 3/16th's od.
WT
88runner [OP]
  • Click me!
« Reply #13 on: Mar 15, 2004, 04:36:12 PM »
Some news,
the front hanger is almost finished, made the hole in the frame, and getting prepared to reduild the axle.
88 4runner v6,
solid axle'd
88runner [OP]
  • Click me!
« Reply #14 on: Mar 15, 2004, 04:38:23 PM »
2
88 4runner v6,
solid axle'd
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #15 on: Mar 15, 2004, 07:53:20 PM »
nice finsh work
trevinotrek
  • Turtle Points: 279
  • Male Posts: 236
  • Member since Sep '04
Re: Finally, starting SAS
« Reply #16 on: Mar 09, 2005, 09:04:03 PM »
right on  i'm rebuilding my front axle now and hopefully gonna get it slung under within the next couple of weeks keep it coming . Got my seal kit from marlin got every thing you need in it.  My hanger is gonna e 2 down and 1 forwad
Thanks
aint skeerd " watch this" ok so maby it was a littlte to bigto get over .Stop laughing and turn me over
jared A
  • Turtle Points: -2
  • Member since Feb '05
« Reply #17 on: Mar 12, 2005, 04:54:37 PM »
what seal kit did you get? and what did you use to cut off the IFS?
88runner [OP]
  • Click me!
« Reply #18 on: Mar 12, 2005, 05:44:41 PM »
got the seal kit from the stealership, it was cheaper for me, get the one from marlin if you're in the USA.
To cut the ifs I just used a bunch of sawzall and a grinder.
88 4runner v6,
solid axle'd
88runner [OP]
  • Click me!
« Reply #19 on: Mar 12, 2005, 05:49:36 PM »
if you want to see the rest go there http://board.marlincrawler.com/index.php?topic=3493.0
88 4runner v6,
solid axle'd
Last post May 18, 2004, 02:22:22 AM
by WHITE_TRASH
Last post Nov 02, 2008, 06:56:41 PM
by Rocksurfer
Last post May 16, 2005, 08:47:43 AM
by chevyLUVtoyota
Last post May 09, 2005, 02:30:28 PM
by WHITE_TRASH
Last post Nov 26, 2006, 08:48:18 AM
by Cheesemaker
