Author Topic: ahhh engine running rough  (Read 2327 times)
4Runninfun
  • Turtle Points: -37
  • Member since Dec '05
« on: Nov 29, 2006, 05:34:16 PM »
i've got an 85 runner 22RE, i just replaced the chain cover gasket, which means almost the entire engine had to be dissembled, now i've got everything back together. and i was pretty careful to make sure to mark all the hoses and wires. but now that i have everything back together the truck will start but it takes some effort and when i get it running it's really rough. in addition my air flo sensor is now slapping open and shut, and being very noisy. i can't figure out why the sensor should be so loud, because i didn't even touch it. so i'm at a loss as to what to do. any thoughts would be greatly appricaited. i'm not a master mechanic by any means so i may have made some stupid mistake (which i'm kinda figuring it is) thanks in advance. Jon
1985 Toyota 4runner, 22-RE bored .050 over, Street RV head, 268 torkr cam, 2" Sus. lift, 2" body lift, 255x85 Trxus MT's, pair of 170 Lightforce, Full-length Yakima Basket. Custom Interior.
olivedrab85
  • Turtle Points: 102
  • Male Posts: 548
  • Member since Jul '05
  • "Ghost ride the whip"
Re: ahhh engine running rough
« Reply #1 on: Nov 29, 2006, 05:51:15 PM »
Prob got it 180 out. Set it at tdc and point the rotor at the first cylinder then time it from there.
"Gotta keep it G rated for Marlin"   my runner http://board.marlincrawler.com/index.php?topic=26527.0
4Runninfun [OP]
« Reply #2 on: Nov 29, 2006, 06:04:52 PM »
i did check the dis. a few times, aimed it at #1,  then pulled it out and went a tooth to the right and left, wouldn't run , i'm pretty sure i have it on the right tooth, but i'm always willing to double check myself.
olivedrab85
  • Male Posts: 548
« Reply #3 on: Nov 29, 2006, 06:07:22 PM »
If the first cyl is a tdc you should be good then.
4Runninfun [OP]
« Reply #4 on: Nov 29, 2006, 06:08:54 PM »
could the TPS be screwing things up?
4Runninfun [OP]
« Reply #5 on: Nov 29, 2006, 07:05:22 PM »
yeah no luck timing should be set pretty close, any other thoughts?
4Runninfun [OP]
« Reply #6 on: Nov 30, 2006, 09:44:07 AM »
nobody else has any idea's?
rage
  • Turtle Points: 26
  • Male Posts: 142
  • Member since Jul '06
« Reply #7 on: Nov 30, 2006, 10:22:45 AM »
maybe clean mass air sensor(carefully) with brakeclean or somethin and check TPS voltage for the hell of it.
toyotatuner
  • Turtle Points: 2
  • Member since Oct '06
« Reply #8 on: Nov 30, 2006, 01:45:16 PM »
make sure its on TDC on the COMPRESSION stroke (both valve rockers will be slightly loose)
if it isnt, you may have a bent valve, 22re is an interference type head.
you could pull the plugs and check compression...
my MAF slaps around too, doesnt affect a thing.
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #9 on: Nov 30, 2006, 02:47:31 PM »
Disconnect any grounds that you forgot to reconnect?  Like at the back of the head or something?
Is the battery ground making good contact to the terminal...my truck runs like CRAP if the battery ground isn't connected well.
I assume you have adjusted the timing by rotating the dist.  and that didn't get you a decent idle?
I bet it is electrical.  Keep checking grounds...
4Runninfun [OP]
« Reply #10 on: Nov 30, 2006, 05:29:31 PM »
thanks, i was figuring it was prolly elect. i'll go and do some testing.
4Runninfun [OP]
« Reply #11 on: Dec 05, 2006, 04:12:45 PM »
ahhh that was it i didn't have it timed on the compression stroke. thanks for the help!!!
Last post May 15, 2005, 08:17:01 PM
by yotapride
Last post Oct 24, 2005, 10:32:27 AM
by 4.3s10
Last post Nov 15, 2005, 04:03:59 PM
by crx-si
Last post Sep 21, 2006, 07:36:26 PM
by yota12345
Last post Feb 05, 2015, 08:31:02 PM
by cosmiccat
