you can rotate you stering box to move the tie rod. but 8 degree shims will afect the caster quiet a bit. maybe rotate the stering box, and use some 6 degree or 3 degree shims. and befor you get the knuckles cut and turnded go for a Dual Transfercase that will make you frount drive shaft 8.5'' longer that will help with drive line angle.
Started by Willy Mammoth Project Research and Build-Ups
Started by don25 Project Research and Build-Ups
Started by 1Bad4Runner Engine
Started by gmrwizard Project Research and Build-Ups
Started by Evilwhitey Newbie Questions
