Author Topic: Intermittant grinding from calipers???  (Read 1530 times)
btn
  • Member since Mar '06
« on: Nov 11, 2006, 12:50:44 AM »
I have an 89 reg cab pickup that is pretty much stock. Several months ago I replaced the front wheel bearings and brake discs with Toyota parts. I also replaced the original calipers with the Marlin units.  I noticed a light grinding feel when braking lightly at low speeds that would happen every once in a while. I replaced the pads from the Marlin calipers with Toyota units and a Toyota shim kit. They never squeek now, but that same grinding is there. I can't find anything else up front that could be causing this.
Anyone have experience with this?
Thank you!
'07 standard cab taco. 2.7L engine, stock 245x16 tires. All stock so far
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
Re: Intermittant grinding from calipers???
« Reply #1 on: Nov 11, 2006, 07:49:06 AM »
It very well could be just the material from the type of pads being used.
btn [OP]
« Reply #2 on: Nov 11, 2006, 04:53:06 PM »
I thought about that also, but the rotors and pads are OEM Toyotas. My thinking was that they shouldn't make noise since they are designed to work together per Toyota.
I was thinking I could try sanding the rotor surfaces and see if that does any good. Anyone know what grit is appropriate for that??
Thanks
« Last Edit: Nov 11, 2006, 05:00:45 PM by btn »
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #3 on: Nov 11, 2006, 05:00:11 PM »
rock or pebble? u shouldn't have to do any grinding or anything
Quote
toynorcal
  • Turtle Points: 96
  • Male Posts: 435
  • Member since Jul '05
  • "Easyline"
« Reply #4 on: Nov 13, 2006, 08:24:46 AM »
Are you sure you getting the grind from the front and not the rear? I'd go ahead and scuff the rotors and pads (anywhere it's glazed) with some fine emery cloth. The OEM parts are great, but you could also try a set of ceramic pads.
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #5 on: Nov 13, 2006, 08:53:58 AM »
Loose wheel bearings can cause intermittent "grinding" noise.  Jack up truck and verify tight wheel bearings.
Last post Sep 26, 2005, 09:01:03 PM
by ksmith
Last post Nov 03, 2005, 03:48:30 PM
by dentedfender
Last post Jun 14, 2006, 08:46:49 AM
by shiftless89
Last post Dec 26, 2010, 05:36:05 PM
by Nimyad
Last post Feb 16, 2012, 05:25:11 PM
by 86bobbedtoy
