how do you convert a 23 spline to a 21 spline
Quote from: stone4x4 on Jan 28, 2004, 06:00:09 PMhow do you convert a 23 spline to a 21 spline 84-88' G52/54 (carb) and 85-95' W56 (efi) trans always have a 21 spline output shaft. There are no couplers made to install a larger 23 spline input gear to the back of these trans. 86-87' R151F (22r turbo) and 88-95' R150F (V6) trans always have 23 spline output shafts and matching 23 spline t/case input gears. There are no couplers made for these trans that adapt to the smaller 21 spline t/case input gear.Hope this helpMarlin
Quote from: Marlin on Jan 28, 2004, 08:18:04 PMQuote from: stone4x4 on Jan 28, 2004, 06:00:09 PMhow do you convert a 23 spline to a 21 spline 84-88' G52/54 (carb) and 85-95' W56 (efi) trans always have a 21 spline output shaft. There are no couplers made to install a larger 23 spline input gear to the back of these trans. 86-87' R151F (22r turbo) and 88-95' R150F (V6) trans always have 23 spline output shafts and matching 23 spline t/case input gears. There are no couplers made for these trans that adapt to the smaller 21 spline t/case input gear.Hope this helpMarlini have a g52 trany i purchased a adapter plate atached to a 23 spline t case. I have bunches of 21 spline t cases what should i do
Started by 4rox Engine
Started by Volcom Engine
Started by navydood Engine
Started by surfindave Engine
