Author Topic: Power steering problem.  (Read 1684 times)
Bass Man
  • Male Posts: 56
  • Member since Oct '06
  • I came to the Dark Side.
« on: Oct 19, 2006, 10:41:08 PM »
3 weeks ago our power steering pump went out on our samurai. The pump was from a 93 suzuki Sidekick.
Today we got a new pump from Hawk and it was a different size; same casing, but the return nipple was 7/16" instead of 1/2"... That problem was sovled with some teflon tape.
Now, the pump isn't putting out much power at all... I mean, it gives out about 50 lbs, but not near enough for our 33's...
Things we have done:
Turn the steering wheel and tightend/loosend the banjo bolt.
Took off the return line; both from the pump and the steering box, and both times it shot ATF 2 feet.
Filled the resevour.
We also put 2 washers in the pressure sensor bolt.
Are we gonna have to rebuild our old pump??
Story about the old pump... We were goofing around and I was gonna do a donut... Missed 2nd and reved it as I turned. About 6000 RPM, the steering went out and the engine died... tried to restart the engine and it squeeld. Then we took the belt off and ran it for 3 more days of rock crawling.
Stock 82 LWB on 33's welded in the rear.  Amazes me!  Been through 4 motors in 2 months though...
  • Turtle Points: 1420
  • Male Posts: 22,622
  • Solid axle Toys Rule ! ! !
Re: Power steering problem.
« Reply #1 on: Oct 21, 2006, 07:34:18 PM »
:aaa:
sounds like the old pump locked up,  not much  you can do there
get a adapter  so that thread  is  tight  and holds pressure
  • Turtle Points: 1784
  • Male Posts: 8,730
  • Member since Sep '05
« Reply #2 on: Oct 21, 2006, 07:42:10 PM »
you fudged 1/16" in thread difference with teflon tape? that jsut doesnt sound good at all
Last post Oct 20, 2003, 12:20:24 PM
by 95TacoTruck
Last post Apr 01, 2004, 12:25:32 PM
by burl4x4
Last post Jan 31, 2005, 07:16:37 PM
by yoderboy
Last post Jul 11, 2007, 07:34:47 PM
by CRS
Last post Sep 18, 2006, 09:08:12 PM
by snowplow
