You gotta put a jack under it where is its bowing...get all your measurements looking good and fishmouth the frame inside and out with some diamond shaped plates. Weld any cracks before hand. The cracks will need to be cleaned and ground out a bit to remove and rust before welding. Then grind the frame smooth again for the braces.
Started by mitchell « 1 2 » Project Research and Build-Ups
Started by burnyota « 1 2 3 » Project Research and Build-Ups
Started by 85 4runr « 1 2 3 » Project Research and Build-Ups
Started by Jud « 1 2 ... 23 24 » Project Research and Build-Ups
Started by *** YELLER *** « 1 2 ... 15 16 » Project Research and Build-Ups
