Reply #4 on: Sep 29, 2006, 09:37:00 PM »
I have a drawer full of old carb kit diagrams. They are generic at best and I have found them to be somewhat useless in some cases.
What year do you need?
Do you have a fax #? This would be the easiest way for me to send you copies of as many as I have at the shop.
Marlin
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
