Author Topic: what aftermarket cam + smog  (Read 2554 times)
TRACKER
  • Turtle Points: 4
  • Male Posts: 442
  • Member since Sep '06
« on: Sep 25, 2006, 05:18:58 PM »
what after market cam are you guy running ? and do they pass smog inspection ?  sorry if this been ask before
i'm in a market for a cam since i have motor torn a part . thanks  :wave:
Pride - is what drive a man to do his very best even when no one is looking ..
CrabDiggs
  • Turtle Points: 16
  • Male Posts: 37
  • Member since Jul '04
  • Grab 3rd!
Re: what aftermarket cam + smog
« Reply #1 on: Sep 25, 2006, 05:57:07 PM »
Theres a lot of companys that make all sorts of different cams for the 22r and 22re.   :help:  It depends on what sort of performance you want more out of your motor.   I personally believe theres no one better to buy aftermarket toyota parts from then T.R.D. themselves.   I went with a T.R.D. mid-range cam which also requires the use of a header(also available from T.R.D.), to displace the exhaust faster.   It didn't mess with my crawling(except for sounding super throaty), but it was night and day on the streets.   well worth the time and coin.   :thumbs:
88' Runner on 40" MTRs. Exo'd, Dual Cases w/ 4.7, 22Re, Waggy Front w/ Fox Coilovers, V6 Rear Still Sprung.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #2 on: Sep 25, 2006, 06:46:58 PM »
the trd stage one does pass smog
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
« Reply #3 on: Sep 25, 2006, 09:05:52 PM »
My Clevite (DANA, available thru NAPA) 229-2293 passes.
TRACKER [OP]
  • Turtle Points: 4
  • Male Posts: 442
« Reply #4 on: Sep 26, 2006, 10:59:09 AM »
THANKS  for all the  reply and info .  i'm not looking for racing cam or anything  just want
little bit of increase in HP and torque for everyday driving  and pass smog .   i'll look into
trd and clevite ....thanks again guys
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
« Reply #5 on: Sep 26, 2006, 11:06:29 AM »
You might also try engnbldr.com. They have a crawler cam that might be for you.
TRACKER [OP]
  • Turtle Points: 4
  • Male Posts: 442
« Reply #6 on: Sep 26, 2006, 11:09:50 AM »
HOTROD - i was looking at those  $88.00   . i'm also getting rebuild  kit from  them .
will their cam  pass smog?
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
« Reply #7 on: Sep 26, 2006, 12:40:33 PM »
That is one thing that I am not sure of.  I am in the same boat as you.  I am going to buy their rebuild kit and 261 C cam as long as it passes smog.  I might e-mail them to find out.
TheBandit
  • Turtle Points: -14
  • Male Posts: 174
  • Member since Jan '06
  • MS in BS
    • www.xtremefabricator.com
« Reply #8 on: Sep 26, 2006, 02:42:01 PM »
I have the EB270 and I am darn sure it will pass smog. I know because I ran one, failed smog, swapped to a stock cam, and failed smog again with nearly identical emissions readings. Turned out I had a bad catalytic converter.
I was very happy with mine on the highway and around town. I still have it, so if you want a used one with about 30k miles PM me. I do not want to swap the cam back in again because its just too much work to do three times in a row!
TRACKER [OP]
  • Turtle Points: 4
  • Male Posts: 442
« Reply #9 on: Sep 27, 2006, 05:13:32 AM »
bandit - i have to take you on that ..
hotrod -will you let me know what you find out ?
thanks guys
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
« Reply #10 on: Sep 27, 2006, 09:17:09 AM »
I will post back here when I find out, hopefully today.
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
« Reply #11 on: Sep 28, 2006, 03:46:40 PM »
Received an e-mail back from Ted at engnblder today and he said he has had many pass smog with the 261 C cam.
TRACKER [OP]
  • Turtle Points: 4
  • Male Posts: 442
« Reply #12 on: Sep 29, 2006, 06:34:27 AM »
thanks   hotrod
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
« Reply #13 on: Sep 29, 2006, 08:34:04 AM »
No problem
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #14 on: Sep 29, 2006, 08:37:24 AM »
www.LCEngineering.com
i run a stage II  race cam, .460 lift  :woohoo:
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
« Reply #15 on: Sep 29, 2006, 08:38:34 AM »
How does it do when crawling?
« Reply #16 on: Sep 29, 2006, 08:48:14 AM »
well,  it idles  a tad ruff,  but when crawling  i run more rpms  cause of the carb
click the link in my sig,  and listen
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #17 on: Oct 01, 2006, 01:02:01 AM »
My buddy's running a Comp Cam.  the 260S if I remember correctly (don't quote me though) and it passes smog.
I'm leaning toward an LC myself.
I like to Drive!
  • Turtle Points: 1088
  • Male Posts: 9,756
  • Member since Oct '04
« Reply #18 on: Oct 01, 2006, 01:30:04 AM »
Turd cams are made by somebody else.  I have a mikuni cam I'm gettin ready to swap in, but I can't remember how big it is.
Last post Oct 07, 2009, 12:24:11 PM
by PhantomD aka Zach
Last post Nov 05, 2009, 08:42:40 PM
by Tw1st3d Up
Last post Feb 01, 2010, 05:58:55 PM
by Jakesteads
Last post May 28, 2012, 05:42:53 AM
by bayou bogger
Last post Mar 14, 2019, 12:10:35 PM
by sjelite
