Author Topic: wheel spacers???  (Read 1091 times)
tominator
  • Member since Feb '05
wheel spacers???
« on: Sep 23, 2006, 01:05:32 PM »
Hello everyone, sorry to ask such a noob question, I tried to use the search but couldnt find an answer.  I am wondering what size wheel spacers I will need to run 35x12.50x15 under my truck without rubbing on the leafsprings?  Right now on my 85 P/U I have 33x12.50" tires with rims that have 3.5" backspacing and just barely turn all the way without rubbing on the leafs.  I plan on running some spacers up front to make the 35's fit with the same rims.  I have an 88 rearend that is 58.5" wide and my front is 55.5" wide.  With some 1.5" spacers on the front, the front would match the rear in width but I am not sure if that will be enough to run the 35's without rubbing on the leafs.  So what size spacers do you think I will need? sorry for the long post. thanks for any help.
-Tom
snowshoebrue
  • Turtle Points: 447
  • Male Posts: 1,152
  • Member since Jun '05
Re: wheel spacers???
« Reply #1 on: Sep 23, 2006, 08:55:33 PM »
i have 37x13.5 with 4" backspacing.  i run 1.5 in spacers.  if you are just going from 33 to 35 but not changing your width you should be fine.
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Full Trucker Effect
« Reply #2 on: Sep 24, 2006, 01:55:52 PM »
You will be fine with the 1.5: wheel spacers.  That's what I run with 36" Iroks.
ga-toy
  • Male Posts: 72
  • Member since Jan '06
  • hiluxin in style....
« Reply #3 on: Sep 24, 2006, 02:09:59 PM »
I run 1.25" spacers in front and back on my 83.  I have ran 36 SSR's and now I am running 35" yokohama's .  Little rubbing on the fender well  but a sawzaw will solve that problem.  You should be fine with the 1.5" spacers though even with the back spacing.  Anything above 1.5 I think would run you into some rubbin issues.    Wheel on! :driving:
bfg KM2's, 3" plain lift, detroit in front hp, twin sticking too.
tominator [OP]
« Reply #4 on: Sep 24, 2006, 07:04:58 PM »
Alright, thanks for the advice everyone, I heard someone from another forum say that it is not a good idea to have the front and rear axles the same it width, is this true?  I was told that the front should be slightly wider than the rear or the rear should be slightly wider than the front, is there a reason for this?
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #5 on: Sep 24, 2006, 07:36:53 PM »
Quote
Last post Nov 21, 2002, 04:21:02 AM
by cruzila
Last post Nov 27, 2002, 09:19:21 AM
by BigMike
Last post Jun 14, 2004, 09:46:45 AM
by 84runner
Last post Sep 24, 2004, 09:23:21 AM
by Bob Garrett
Last post Nov 03, 2004, 04:49:33 PM
by GrimReaper
