i've hear of running a trac bar to the top of the housing can correct this but will inhibit some of the travel.
I would say that if you use a shackled trac bar that it will Not limit any travel at all. Please refer to my drawing below. That is how I am going to do mine.
Next is my motor. I love the 3rz I think it has a lot of potental and is bullet proof. I am running LC headers, K&N intake and an E-Fan. Not totally sold on the e-fan just yet because i havent got to run it for a while with it on. I am curious for all of those who have a S/C are they happy with it, the gains, the install, the reliability, and over all.
Well, hmmmmmmmm about the 3RZ Supercharger from Alpine (used to be sold through TRD)......... yeah.
I don't know man. I really have mixed feelings about it.
For starters, I installed it with the stock pulley, which is rated at 4psi, and the thing would only get 2 psi near redline. Then I installed a 6-psi pulley and it now will get about 4.8 psi right before rev cut.
I don't get it. Everything looked great internally as I opened it up to inspect it as I have removed the blasted thing probably 3 times now. I don't know what the clearances between the rotors are supposed to be, and I had no way of checking that, but cosmetically, everything looked great. There were no unusual wear marks on the rotors and it looked very clean, no chips, nothing had accidentally been sucked into the blower or anything. I checked the Eaton By-pass valve and I verified that it was closing in the correct position and that it was properly sealing. Everything looked great with it. BTW, this is a used unit with apprx. 15k on it, is what I think I was told when we got it this May. Either 10k or 15k, I am not sure. But it was very clean, had never been dropped, etc.
So for instance, if I just go out and drive my truck down the road, at 2,500 rpm I can floor it and it will go straight to 3psi. This is typical of a Supercharger. But what it not typical is that with increasing RPMs, it will begin to climb up to 3.5, 4, 4.5psi and a bit higher just before I hit 5,750 rpm.
I maintain that a M62
IS WAY TO SMALL FOR A 2.7L ENGINE. The M62 is what Jackson Racing and other Honda SC companies put on 1.8l engines. I mean its a whole litre less for crying out loud. I don't know why we have to spin the blower at near its rpm limit (which I believe is about 16,000 rpm for a screw-type Eaton) when we could have the same effects by turning a larger M90 blower at much slower speeds but with the same amount of boost (because its a larger displacement). I understand how more sc rpms will give better boost at lower engine rpms, but the dang thing can't even develop what it is rated for anyways! geez
So now that you have heard all of that, here is my impression on driving it. And this is the good news that you are looking for. Yes, it definitely has much more power, especially when it is running right. I am still waiting to get the Fuel Piggy-back control unit, so my engine likes to run a bit on the lean side. So on some good days I will have LOADS of power, but at other times it will start pulling very hard, but by the time I get to 3rd gear, you can definitely tell there is a lack of power. And this has been confirmed using my OBD-II Scanner. It drops the timing by about 8 degrees when its not running right. That is a lot of detonation it is trying to counter. Now I do have a DIY Water/Methanol inj. system installed, but right now it is not working because I keep locking up my antisyphon solenoids because I am using vacuum parts to handle liquids. With the meth. turned on (I like calling it just "meth" hahahaha) it pulls VERY HARD and I like to imagine that this is what it will feel like once I get the piggy-back computer in place.
So definitely, if you are going to SC your 3RZ, I would IMMEDIATELY 160% ENTIRELY recommend paying extra for the piggy-back computer. We only get 91 oct fuel out here, and it is DEFINATELY not enough with the stock fuel curve to prevent detonation. And I am only running about 4 psi on average anyhow. What happens when I put an even smaller pulley on and I get 6 psi? Then I'll really be having fuel problems without the piggy-back computer.
Anyhow, that is a lot to ponder, so let me know what you thoughts are after reading alllllllll of this and we can go from there.
Now I've got a question for you
![Gap :gap:](https://board.marlincrawler.com/Smileys/marlin/gap.gif)
How do you like the LC Header? We had a customer come in (to the automotive side) who blew a head gasket on a '97 Taco 3RZ. I must have walked back there (to the other shop) numerous times to investigate what a 3RZ looks like opened up. That motor is so nice to work on. Its valve train is very very simple and exactly like my good ol' 4A engines I know so well.
Now as for my question, I noticed he had a LC Header on it. I was looking at how looooooooong the pipes are and I don't think it would be possible to run on my setup because of that. I would need to modify all four pipes.......... so I went back into the shop (
![Marlin Crawler Turtle Logo :turtle:](https://board.marlincrawler.com/Smileys/marlin/turtle.gif)
) and I mentioned all this to Marlin, and he had not only already known about the job next door, but in fact he had already spoken to the owner of the Tacoma.
It turns out that the owner previously had a Downey header, like what Dean, Marlin, and myself are all running, and he came across a good deal on a LC Header and he thought he would compare the two. And "WOW! Night and Day difference" is what he told Marlin. The guy said that the engine came alive after he put the LC Header on.
So I am just wondering what your thoughts are about the LC Header? How do you like it? Have you driven a 3RZ with a Downey header? If so then how do you compare the two?
