Author Topic: electrical issues major  (Read 2273 times)
snowshoebrue
  • Turtle Points: 447
  • Male Posts: 1,152
  • Member since Jun '05
« on: Sep 04, 2006, 07:28:36 PM »
so earlier today my truck was running just fine.  i disconnect the battery to weld on my truck and now i have absolutely no power in my truck.  battery is fine i have power to my auxillary fan and all my rock light just not to the truck itself.  is there a main fuse somewhere i could have blown. i looked in my fsm and it tells me jack. where i was welding was on the back of the truck and i had the ground lead about 12 inches from where i was welding.  please help i don't want to miss the roudup because of this
 by the way it is an 83 with the stock motor.  only thing that is not stock is the coil but it was running with it earlier                                    thanks justin
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
Re: electrical issues major
« Reply #1 on: Sep 04, 2006, 07:59:50 PM »
Have a look in the black box on the left side of the engine bays.  Those big fuses in there are the fusible links.  They control the whole shabang, if you blew the black one the trucky no start.  Check all other fuses and see if any of your grounds have come undone.  Also, check your starter and make sure both leads are plugged in, sometimes mine will jimmy its way free.
snowshoebrue [OP]
  • Male Posts: 1,152
« Reply #2 on: Sep 04, 2006, 08:59:56 PM »
is this what you are talking about.  found it on the drivers side by the coil
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
« Reply #3 on: Sep 05, 2006, 02:12:10 PM »
Nope, thats the voltage regulator.  follow the pos wire from the battery.  The big one goes down to the starter, and a smaller one goes to the fuse/relay box right behind the battery.
snowshoebrue [OP]
  • Male Posts: 1,152
« Reply #4 on: Sep 05, 2006, 05:40:32 PM »
found it she starts now thanks for the ideas.  i brought my meter home with me today and did a little ohm reading and got her figured out. p.o. must have eleminated the box you guys are talking about cause it aint there.
CTENG in KS
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #5 on: Sep 05, 2006, 06:35:19 PM »
You don't have the black box with the green writing?
snowshoebrue [OP]
  • Male Posts: 1,152
« Reply #6 on: Sep 05, 2006, 08:04:54 PM »
nope and i was looking for one but no luck.  i have one under my dash but it is all 7.5 10 and 15 amp fuses for stuff like blinkers, gauges small stuff
Crawler677
  • Turtle Points: -43
  • Male Posts: 324
  • Member since Oct '05
  • BRRAaappp!
« Reply #7 on: Sep 07, 2006, 08:52:49 PM »
 :screwy:
82rustbeast
  • Turtle Points: 318
  • Male Posts: 500
  • Member since Sep '05
« Reply #8 on: Sep 09, 2006, 12:55:49 AM »
Hey CTENG in KS, the reason why the dude doesn't have the fuse box in his 83 is cause ur engine is a later model. There is only a fuse boxe in the cab on 83's  :slap:
Last post Aug 08, 2007, 03:46:02 PM
by KDXSR5
Last post Jun 12, 2009, 07:31:36 AM
by Doable
Last post Apr 05, 2011, 04:11:35 PM
by Stocker
Last post Sep 15, 2011, 03:39:29 AM
by b_sherwood3
Last post Oct 29, 2011, 03:30:36 PM
by dirtybird
