Author Topic: High-steer question  (Read 2192 times)
88runner
  • Turtle Points: 756
  • Member since May '03
  • Click me!
High-steer question
« on: Jan 14, 2004, 01:27:44 PM »
Ok, I'm doing a SAS on the runner, what i want to know is with approx. no drop in the hanger, maybe like 1/2" or little more, rears springs up front, will the high-steer have clearance issue.
On PirateBB one guy say that it may come in contact with the frame an the other say it don't, now I want to make it clear. :headscratch:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
gferris5
  • Turtle Points: 7
  • Member since Oct '02
Re:High-steer question
« Reply #1 on: Jan 14, 2004, 02:01:42 PM »
I don't know specifically in your case, but i do know that you can gain some clearance by rotating the steering box, but that depends on if you're moving it in the first place, shouldn't be too hard to clamp it in place and see.
yotacrawler85
  • Turtle Points: 2
  • Member since Nov '03
  • east coast ROCKS!
« Reply #2 on: Jan 14, 2004, 08:53:07 PM »
i did sas on my truck and i used all pro high steer .. i also used a toyota rear/izuzu trooper rear spring combo which gave me a little more lift than just toy rear springs and i have absolutely no clearence problems
85 cab on a 87 sas frame with 6 inch lift, 15x10 wheels, 34-10.50 swampers, all pro high steer, shock hoops, dual diff guards, in cab roll cage, rancho 5000s, all poly bushings remote diff breathers front and rear recievers, welded rear(4:30's) 22re
88runner [OP]
  • Click me!
« Reply #3 on: Jan 15, 2004, 07:03:14 AM »
Thanks guys now I will see for my application if there is any problem.
Now I just need to start cutting but it's freakin -40°C(or fahrenheit same thing) out here for almost 2 week and the runner won't start.
88 4runner v6,
solid axle'd
84runner
  • Turtle Points: 99
  • Member since Dec '02
« Reply #4 on: Jan 19, 2004, 12:30:41 AM »
Whose steering arms are you using?
88runner [OP]
  • Click me!
« Reply #5 on: Jan 19, 2004, 08:54:15 AM »
I use the OTT kit, I would have buy the marlin crawler kit but the border make me mad(have to pay hell more)
88 4runner v6,
solid axle'd
fourwd1
  • Member since Sep '02
  • Out On Bail
« Reply #6 on: Jan 19, 2004, 06:53:00 PM »
Using rear springs up front will move your axle forward ~2", so you will have to relocate the box. I too have rears up front and moved the box as far forward as possible, even cutting into the body mount.
You may also have to clock it somewhat so the drivers side spring doesn't hit the pittman arm under full compression, yet not too much that it hits the underside of the frame when turning.
C-clamp it in place and double check everything first.
Be sure to add some reinforcement plating under the box on both sides of the frame.
'80's Toyota 4WD P/U, Buick 231 V6, Holley 4 bbl, Weiand intake, Downey headers, custom TH-350 L/U w/700R4 low gearing, dual tanks, dual batterys, other crap ...
- - - as seen in FOUR WHEELER magazine July 2006 - -
84 4Runner ARBed 5.29's F&R, 4.7 t-case, x-over, Chevy's, 2" drv train lift, 36" TSLs, 30 spline Longs, BudBuilt skid
Last post Apr 21, 2006, 11:19:59 AM
by synwars
Last post Jan 11, 2010, 10:06:24 AM
by Volcom
Last post Aug 09, 2010, 10:59:29 AM
by Mavericks
Last post May 13, 2013, 11:18:01 AM
by BHT12
Last post Sep 20, 2016, 07:24:21 PM
by john90lux
