Author Topic: Standard guage panel to SR5 gauge w/tach install ???'s  (Read 2401 times)
Lonestar Honcho
  • Member since Feb '06
« on: Aug 30, 2006, 05:20:51 PM »
I found this topic awhile back when I first became a member but now I can't find it at all.
I'm wanting to install a SR5 gauge cluster panel into my '82. Reason being is the tach that's a part of the instrument panel. One thing I saw, on the previous mentioned search, was having to install a wire from the coil to the cluster. Is that all there is? Where do I install the wire into the cluster?
Appreciate the help. :biggthumpup:
DD '82 Toyota 4WD LWB, L-52HD, 31" BFG's, 3" Skyjacker, Orig. Blue paint with AC.
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
that and you have to use an SR5 OP sending unit
heres the link to Brandons thread. I did it in my 83 and its easy just take your time
http://board.marlincrawler.com/index.php?topic=2973.0
Ewong
  • I love Marlin Crawler!
FSM should tell ya where the wire goes. Id try to get a plug form a junkyard to make it plug and play...
But an off the cuff guess is the wire may alreayd be int he plug - just not in the harness.
In the WORST case - you'll have to use a "eye" crimp ocnnector tothe back ot he "bolt" that holds the tach to teh cluser/trace  (what it looks like on th e85-88 ones anyway)
yeah yeah - still IFS...
Lonestar Honcho [OP]
Thanks for the replies guys...<BIGThumbsUP!>
Kyota, whats a SR5 OP sending unit? You mean something like the wiring harness that plugs to the back side of the gauge cluster? Or could I just "run" a wire?
Also, will the igniter "yellow wire" be fine for the connection to the tach and/or will I need a wire to the coil too?
KYOTA
  • Wreckin Ball '09
op sending unit= oil pressure sending unit. you have to replace the non sr5 sending unit with an sr5 sending unit or it will fry the gauge
Ok, thanks again. Sorry for being such a newb...I'm trying my best! :yesnod:
Last post Jan 15, 2006, 09:09:47 PM
by Crucial
Last post Dec 04, 2006, 06:23:48 PM
by Lonestar Honcho
Last post Jan 12, 2007, 06:30:09 PM
by Lonestar Honcho
Last post Feb 19, 2008, 01:25:05 PM
by Duffil
Last post Jul 29, 2016, 01:03:37 PM
by OVRAROK
