Author Topic: non cv drive shaft ???  (Read 916 times)
Makohon
  • Turtle Points: 83
  • Member since Sep '04
« on: Aug 29, 2006, 06:26:22 PM »
sooo with the non cv style d shaft have to have both flanges at the same angle? or do you just set the rearwith the pinion pointing up  making the rear u joint/flange level with the shaft? dont know how clear that sounds but.... also when i was setting up my pinion angle with the d shaft... i jacked up the rear and put it in gear and it would wable up and down.... thought this was weird so i went out to my stock 2wd truck and did the same thing and th d shaft wabled up and down... so i assume this is normal? thanks guys!! :beerchug:
ddement
  • Member since Mar '06
Re: non cv drive shaft ???
« Reply #1 on: Aug 29, 2006, 07:47:06 PM »
The flanges have to be parallel with the non CV shaft. Do not point it at the t. case or you will get serious vibration.
Last post Jan 13, 2008, 04:42:07 PM
by Lizard_lips
Last post Jan 20, 2008, 06:13:25 PM
by Gittinit
Last post Mar 20, 2008, 09:03:58 AM
by FIREBALL
Last post Apr 19, 2008, 12:21:04 PM
by Lizard_lips
Last post Jun 17, 2010, 04:44:33 PM
by 8D3TOY
