Author Topic: need info on SOA....  (Read 3291 times)
solidaxle16
  • Turtle Points: 35
  • Member since Oct '05
« on: Aug 24, 2006, 02:19:53 PM »
this is on a stock 75 fj40.... to do SOA on this thing, would the stock steering arms(tie rod, drag link) need to be replaced??? or would the stocks work,,,, do i need to go with hy-steer kit conversion....
LCOwner
  • Turtle Points: 50
  • Male Posts: 302
  • Member since Dec '02
  • Have you seen his shop OMG!!!!
    • Cruiser Build-up page.
Re: need info on SOA....
« Reply #1 on: Aug 24, 2006, 02:42:38 PM »
You could use them but a very custom 'S' drag link will beed to be fabricated.  This will bring on a mean bump steer problem.  You will be money ahead getting a high steer kit.  I assume you're running a saginaw style PS steup behind the front bumper.  If not you should look into it.
« Last Edit: Aug 25, 2006, 07:01:51 AM by LCOwner »
'71 FJ40, 350 TPI/420, 4.70/mini, 60's/5.38/42's, under construction.
'83 FJ60, SOA underway.  Soon to have a Police 350TBI/700R4/.....
Hill Hoppers Central Valley 4 Wheelers - Founding Member
Four Wheel Drive Club of Fresno - #1127
greenfox
  • Male Posts: 66
  • Member since Dec '05
« Reply #2 on: Aug 24, 2006, 08:31:54 PM »
Go with a hy- steer kit it will make life easy.
67fj45lpd
73fj40
74fj40soa
97fzj80
Weak-Link
« Reply #3 on: Aug 24, 2006, 11:52:41 PM »
A kit like Marlins is the best, but if your not running late model knuckles you don't have to many options.
4x4labs makes a set of arms that will fit any year knuckles.
I sent my arms to W.   http://www.overthehill4x4.com/index.html    for  80 bucks I had my stock arms heated and bent up to clear the springs. I've been running them for two years now on a dd
Jason
fj40forlife
  • Male Posts: 156
  • Member since Jul '06
« Reply #4 on: Aug 31, 2006, 12:03:49 AM »
i went with man-a-fre steering arm. and if you have stock steering your link well hit the shock
120 Fabrication
ranger
  • Male Posts: 17
  • Member since Nov '05
« Reply #5 on: Sep 10, 2006, 07:54:25 PM »
YOu wont be able to use the stock arm on the passenger side, you can either have a double arm fabbed (hard to find anyone that will do this...liability reasons) or get a small bolt pattern double arm from aqualu. Or you can do the high steer route.
Be better just to upgade to mini outers and get the larger bolt pattern arms.
fj40forlife
  • Male Posts: 156
« Reply #6 on: Sep 12, 2006, 08:40:17 PM »
man-a-fre sell them
120 Fabrication
kilercl0ne
  • Male Posts: 14
  • Member since May '06
  • noway bro
« Reply #7 on: Oct 08, 2006, 12:10:55 AM »
I asked the owner of downey off road at the "OFF ROAD EXPO " in pomana ca LA fairgrounds  i.e. today ?~~> do you make a high steer 4 an fj40 he said yes & no onlly works on 1979 and up knuckles  lucky mines a half arse fj60 disk brake on an early 1972 axel so downeys got them on their site but no price so you got to call em  ,& 4 the record I only go to downey offroad cause they'er close to where I live so give me no flack , next is spring over and I have more than 1 cruiser to do , I got perches and a welder now what ?1975 v-8 p/s stock 4sd trans ?
fj40forlife
  • Male Posts: 156
« Reply #8 on: Oct 26, 2006, 09:44:01 PM »
Do one thing at a time. hows your motor that you have in there right now. good ???? if so keep it. I like my 2f But I have some few mods done to it like carb heads k&n muffler. coil dis. and more stuff
120 Fabrication
Hammerhead
  • Turtle Points: 100
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
« Reply #9 on: Jan 28, 2007, 05:26:27 PM »
As aforementioned the stock arms will give intolerable bumpsteer.  Ask me how I know this.
The next option is the Aqualu double arm on the passenger side.  Better, but still not great.
High-steer is really the best bet and there are many ways to accomplish it.  For a good high-steer set-up you must swap out your knuckles to FJ60 or mini-truck knuckles and brakes which is something you will want to do anyway.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
ranger
  • Male Posts: 17
« Reply #10 on: Feb 04, 2007, 09:04:14 PM »
Had double arms on three rigs with no bumpsteer issues...............
Last post Jul 27, 2006, 01:23:57 PM
by Plowking
Last post Feb 09, 2012, 03:07:11 AM
by zippo
Last post Jan 23, 2012, 05:59:41 PM
by 4RunnerChevy
Last post Aug 19, 2012, 06:45:59 AM
by toygasm
Last post Nov 09, 2012, 08:57:11 AM
by OOPS
