Author Topic: Cutting Brakes  (Read 1876 times)
RynothealbinO
  • Turtle Points: -15
  • Male Posts: 141
  • Member since Aug '06
  • 36's on no lift!
Cutting Brakes
« on: Aug 21, 2006, 10:19:09 PM »
    :help:Hi, I managed to break my parking brake cable on my '84 4Runner so I was thinking about making cutting brakes.   For those who dont know cutting brakes allow you to apply the brake to the left or right wheel individually.  This could be used to take the place of a locker and also be used to aid in hard cornering (if you know what you are doing).  I was thinking that I would run two seperate cables to the left and right parking brakes and make two seperate handles to pull the cables.  Mount some pulleys to route the cables and your done, right?  If anyone has done this or has any comments or suggestions please let me know.  Thanks in advance. :turtle:
Trust in the LORD with all your heart and lean not on your own understanding, in all your ways acknowledge him and he will make your paths straight.  Proverbs 3:5-6  Don't let anyone look down on you because you are young, but set an example for the believers in speech, in life, in love and in purity.  1 Timothy 4:12
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: Cutting Brakes
« Reply #1 on: Aug 21, 2006, 10:46:22 PM »
This has been tried before.
Could not get enought force to lock up the axle from the brake shoes or disk pads.
Also, too much to do and still drive the truck. Hard to pull cables and still work the gas ect.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Cutting Brakes
« Reply #2 on: Aug 22, 2006, 08:09:29 AM »
and he knows,  they had cutting brakes on the F toy,  but they arent there anymore
RABIDYOTA
  • Turtle Points: -107
  • Male Posts: 336
  • Member since Mar '06
Re: Cutting Brakes
« Reply #3 on: Aug 22, 2006, 08:18:37 PM »
worked great on my baja. but i would go with a hydro unit now.
RynothealbinO [OP]
  • Male Posts: 141
  • 36's on no lift!
Re: Cutting Brakes
« Reply #4 on: Aug 23, 2006, 10:58:14 PM »
  :dunno: How would a person go about doing it hydraulically?  I have seen brake proportioning valves made by willwood and other companies and was wondering if you could use one for cutting brakes.  You would have to depress the brake pedal to make it work but that would also put the front brake on.  I have also heard of hydraulic parking brakes that you could use but have been unable to find any.  :turtle3:
RustRunner
  • Turtle Points: -55
  • Male Posts: 51
  • Member since Nov '05
Re: Cutting Brakes
« Reply #5 on: Aug 24, 2006, 01:01:43 PM »
most forklifts have hydo park brakes AFAIK, so try a forklift supply/repair place.
RABIDYOTA
  • Male Posts: 336
Re: Cutting Brakes
« Reply #6 on: Aug 24, 2006, 05:59:16 PM »
look at any dune buggy, you can order a single or twin lever set up. you can usaly find one at a vw parts house.
Last post Jun 27, 2006, 09:34:25 AM
by Weldo
Last post Jan 18, 2008, 06:53:59 PM
by kneedownnate
Last post Oct 08, 2008, 07:22:43 PM
by Rix86
Last post Mar 05, 2010, 02:58:06 PM
by rustyboltz
Last post Dec 12, 2018, 06:54:50 AM
by 300k
