Author Topic: To flex fan or not to flex fan  (Read 9663 times)
  • Turtle Points: 1425
  • Male Posts: 22,629
  • Solid axle Toys Rule ! ! !
« on: Jan 09, 2004, 05:45:19 PM »
 :smack:ok,   there has been some discussion on the flex fans,
my fan clutch is toast should i replace it or go with the flex fan kit from LCengineering,  i personally want the flex fan, but will reconsider if i get alot of negative feed back :dunno:
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
Re:To flex fan or not to flex fan
« Reply #1 on: Jan 09, 2004, 06:36:29 PM »
see other post.
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #2 on: Jan 11, 2004, 10:02:25 AM »
flex fans are to noisy.  and I've heard of them braking,mostly at high RPMs. and that would not be a good thing. go elctric fan
84runner
  • Turtle Points: 99
  • Member since Dec '02
« Reply #3 on: Jan 11, 2004, 11:28:01 AM »
I heard they can rob you from a little power too, cause how much air they move especially on a 4 cylinder
kauaiboy
  • Member since Jan '04
  • Low Riders are for gays who cant get it up!
« Reply #4 on: Jan 11, 2004, 02:34:59 PM »
I dont know about that cuz I have a friend who swears by it.
89 Toy   7" lift, 36" tires, all balls
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #5 on: Jan 11, 2004, 05:06:40 PM »
I know for sure that they can cut you bad. must be realy carful with them when ajusting your timing ect.
Toyoballs
  • Turtle Points: -164
  • Member since Dec '03
  • The Slow and The Dangerous!
« Reply #6 on: Jan 11, 2004, 06:16:59 PM »
  i personally want the flex fan,  :dunno:
Why do you want to run a flex fan anyway??? :headscratch: ???
Just Grind It Down To Metric...
"MAKE IT OR BREAK IT"
Extreme Off-Road Club
89 toy
  • Turtle Points: -1198
  • Male Posts: 383
« Reply #7 on: Jan 11, 2004, 06:20:10 PM »
flex fans suck.if you go in any water say good by to the radiator. my buddy did it 3 times on his 65 ford before he went to electric fans
Toyoballs
« Reply #8 on: Jan 11, 2004, 06:29:33 PM »
This guy I meet this weekend has a 70's Bronco with an Electric fan he's replaced twice from blades braking off from water.  :smack:He said the blades flex forward from the water and pull them in to the fan motor mounting bracket braces and brake the blades off :shake_head:
« Reply #9 on: Jan 11, 2004, 06:47:43 PM »
sounds like that dude need to install a dp dt (double pole double throw) switch in for the fan.  That way he could kill the fans for deep water.  On another note you would think he would learn...kids these days! LOL
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #10 on: Jan 12, 2004, 06:35:30 PM »
I have two elc. fans on my truck, one has a swicth to trun it on/off. the other is on a themal switch, but i think if i went into the water it would shut down fast from the cold water cooling off the rad. unless you just had to "charge" the water.
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #11 on: Jan 12, 2004, 06:36:32 PM »
:wave: hi marlin
kauaiboy
« Reply #12 on: Jan 13, 2004, 04:32:41 PM »
Are there any electric fans available to strip from a stock vehicle somewhere? Is it even stock on any vehicle?
kauaiboy
« Reply #13 on: Jan 13, 2004, 04:34:11 PM »
Is it a good idea to trim or drill holes in my stock fan I have now to reduce some engine drag on my 22RE?
84runner
  • Turtle Points: 99
« Reply #14 on: Jan 13, 2004, 04:47:38 PM »
Try it a tell us if it works
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #15 on: Jan 13, 2004, 05:17:39 PM »
hummmm, you could drill a lot of holes in your fan. that would help with going though water:thumbs: bigger is better!:laugh:
84runner
  • Turtle Points: 99
« Reply #16 on: Jan 13, 2004, 06:01:34 PM »
 :yupyup: :yupyup: :yupyup: :yupyup: :yupyup: :yupyup: :yupyup:
Toyoballs
« Reply #17 on: Jan 14, 2004, 06:44:40 AM »
 ??? Anyone ever heard of or done the Ford Turius (Not sure how to spell it) electric fan swap???
hawaii500_1999
  • Turtle Points: -7
  • Watch this!!!!!
« Reply #18 on: Jan 14, 2004, 04:12:28 PM »
i had a flex fan come apart on me.  took out my radiator and top hose and went through the hood.  they are noisey and do not cool as good as a clutch fan.
i won't run one again.
you know the toyota clutch fans can be refilled with the silicone oil.  the bottle costs about 8 bucks from the dealer.  get two bottles just in-case you drip some like i did.
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
« Reply #19 on: Jan 14, 2004, 09:05:39 PM »
The taurus fan is pretty popular it works real good and is super cheap from the yards.
Ferg
  • Turtle Points: 416
  • Male Posts: 577
  • Member since May '03
  • That was EASY!!
« Reply #20 on: Jan 19, 2004, 07:14:14 PM »
Stick with the stock fan clutch.  No wires, no adapters, works fine lasts a long time.  Tried all the other crap and went back.
kauaiboy
« Reply #21 on: Jan 20, 2004, 04:43:43 PM »
Is the Ford Taurus electric fan available with most years? (if you'd happen to know)
84runner
  • Turtle Points: 99
« Reply #22 on: Jan 22, 2004, 09:45:10 PM »
So what u gonna due?
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #23 on: Jan 22, 2004, 09:48:43 PM »
Glen already put a stock fan back on......chicken
mr4x42u
  • Turtle Points: 700
  • Member since Sep '02
  • LOCKED AND LOADED
« Reply #24 on: Jan 23, 2004, 06:11:32 AM »
I have the black magic fan..Its been pretty good however it was not always that way.I ended up having to use a ford starter solenoid as a relay to keep it running on long trips or times when its on forever..I would not buy one new.There spendy..I got mine chep from a guy and it was like new..The rebuild of the stock clutch is best unless you see your self in deep ass water.No way would I drill holes in a fan..You run a risk of hairline cracks and broken blades and damage to yourself and your rig..Flex fans are for hot rods..Water hits them and the blades will bend bad..So if you don't do damage to your rig it won't cool the same abd your still screwed! :beer:
« Last Edit: Jan 23, 2004, 06:12:21 AM by mr4x42u »
Brandon
  • Hawk
  • Turtle Points: 193
  • I believe in Life before Death
    • www.RiverCityRockCrawlers.com
« Reply #25 on: Jan 23, 2004, 01:50:28 PM »
I have it and am GIVING it away, it draws a waaaay to much! I had to get a hi-output alternator and then I needed an expensive 75 amp relay (like $50) and it still causes issues because it draws so much. I went with a spal for about $80 and it only pulls 8amps!
Brandon Miller
RCRC, Sacramento, CA
84runner
  • Turtle Points: 99
« Reply #26 on: Jan 26, 2004, 10:37:51 PM »
Smart choice Glen
Josh
« Reply #27 on: Jan 29, 2004, 03:43:44 PM »
I have heard that the electric fans from a Camry work well.
79coyotefrg [OP]
Re: To flex fan or not to flex fan
« Reply #28 on: Apr 26, 2004, 06:26:24 PM »
actually i just went to oriellys and got a new fan clutch,  but if i went electric fan it would be from a toyota car,  camry,corolla
its running much cooler now,  when i had the head off i opened up the water jacket holes in the head gasket,  why dont they punch all the holes inthe head gasket
ezthere
  • Member since Feb '04
  • 85 4runner, worked 4.3L V6. 300HP.
« Reply #29 on: May 01, 2004, 11:36:34 AM »
I am running a flex fan. NP yet. with my set up I still run 150 deg..Crawling on the beach it peaks to 190deg. The fan does flex allot. When I race I can hear the fan flexing so much it hit the engine oil cooler..
Remember I am running flat top pistons a big cam, in my 4.3L..No cooling problems at all..  :beerchug:
Chuck
Last post Apr 30, 2004, 05:19:53 PM
by 84runner
Last post Oct 04, 2002, 04:12:43 AM
by cruzila
Last post Apr 24, 2003, 03:20:07 PM
by 408jigga
Last post Dec 31, 2010, 05:40:14 PM
by zippo
Last post Jan 27, 2020, 09:56:12 AM
by KauriJ
