I hated that, I was always rubbing the paint off my towers, if the 3" only makes you 1" over stock that would be fine as long as you don't have some wild offset on the rims.
I went 2" spacers when I had toyota axles and loved the wider stance.. made the truck much more stable but I had to cut the kick panels back alot so they didn't rub.
The more spacer you use the farther the tires will move front and back when you turn. Also the more strain you put on the stearing componets as well as bearings and spindles.Can't you just move the shock hoops?
When you gonna do a 3RZ swap so you can get a toyota trans in that thing?
start over with fullwidth axles
FFC,doesen't Marlin sell them?.
GO HERE FOR GOOD SPACERS, this guy has them. You won't find them cheap but they are worth every penny.
Yes, but I can't afford the $240 + shipping right now Unless my boat sells before then
Don't sell Grandpa's boat!
Started by MidgetMike « 1 2 » General 4WD Discussion
Started by Marketing General 4WD Discussion
Started by jared A General 4WD Discussion
Started by shad « 1 2 » General 4WD Discussion
Started by 84xcab General 4WD Discussion
