How many miles are on it? Maybe the rings havn't set yet. I had a rebuilt small block in a Blazer that burned oil bad even after 1000 miles. Turned out that when I installed the intake I pinched the gasket and it was sucking oil from the lifter valley. Not sure if a 22re could do that but it might be worth looking into.
Perhaps I am confused, but I would think you might want to do a compression check and see if your rings are toast and maybe change head gaskets. It doesn't seem that the head would be the first thought when burning oil.
Started by booger1 General 4WD Discussion
Started by Shamb Engine
Started by Zoomschwortz Toyota Pickup/4Runner Tech 1979-95
Started by Tice Engine
Started by GJToyotabug General 4WD Discussion
