you will rub if the springs are soft enough
yea ..also i was thinkin about gettin the interco trxus mud terrains has anyone had any experiance with them ?
what do you mean by that ? like bottom out ?
what i mean is...lets say your turning into a driveway, the spring will compress right when one tire begins to go in...this is where i rub. pound the fender in a little, that helps. you'll rub more if the springs are softer.
Started by CTENG in KS General 4WD Discussion
Started by Rebeltilldeath3 « 1 2 3 4 » General 4WD Discussion
Started by toy85ota Tire and Wheel Tech
Started by mcg_916 General 4WD Discussion
Started by Grimmjow Tire and Wheel Tech
