Throttle cable, YES. Sorry don't know about the rest
There are differences in the AC vs No AC harness, However its only a switch. However you will have to add heater core deal under the dash, and plumb it to get the AC to work. That pretty much means that you will need the dash out of your Buddy's truck too...
I am getting ready to buy both a new dash and a/c parts for my non a/c '85 Pick-up. So what all problems will I run into trying to do this? What will need to be done to easily put a/c in my truck? I live in Las Vegas where in the summer it can get up to 120 degrees and I NEED a/c.
I'm doing something like this myself, mixing an '84 truck with an '86 EFI system and some other stuff.The 89-95 efi system is the easiest to swap. All the wiring for the engine/efi are integrated into the engine harness and you can hook up everything at the chassis plugs inside the cab. The earlier system has the wiring for the coil/igniter and the MAF built in the chassis harness and you have to swap everything or make a sub-harness for those items. I'm swapping everything on my '84 body because I have all the stuff, I've also done the sub-harness thing on a 94 2wd body/86 4wd frame swap.You need the tank with pump and the supply lines with the threaded fittings. Also need a return from the fuel rail to the tankYou also need the RE throttle cable. The AC wiring should already be in the harness. It appears there's a section of ductwork in the heater system under the dash that can be replaced by the evaporator box, I can't verify because I don't have an AC equipped truck to look at - just pay close attention when you're stripping off the AC stuff and you should be able to figure out what you need pretty quicklyCan't help you with the shifter stuff, haven't been there yet
Started by vikingsven Project Research and Build-Ups
Started by tribliska General 4WD Discussion
Started by Volcom Engine
Started by mntgoat Engine
Started by wrenchtech Toyota Pickup/4Runner Tech 1979-95
