Author Topic: Fuel Pump Question  (Read 1328 times)
crx-si
  • Turtle Points: -134
  • Member since Nov '05
Fuel Pump Question
« on: May 30, 2006, 05:26:54 PM »
Wondering if a mechanical fuel pump from a 22r will fit a 22re block and also is there a rod that is needed to run off the camshaft like in a small block chev.
synwars
  • Turtle Points: 360
  • Male Posts: 485
  • Member since Mar '05
  • Fabbing with Maffy
    • Can you feel the love?
Re: Fuel Pump Question
« Reply #1 on: May 30, 2006, 06:34:35 PM »
The mech fuel pump has two bolts that bolt to the head not the block. It bolts onto the intake side at the front. There should be a port there, maybe with a plate on it depending on the years, I'm not 100% sure on that part. The mech pump has a lever that runs on a cam that is bolted on the front of the cam shaft. Check out a haynes manual for a visual. :thumbs: Sorry my descriptions aren't the best...
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
crx-si [OP]
« Reply #2 on: May 30, 2006, 06:43:32 PM »
Ya sorry i meant the head so it dosen't have a rod, it runs off the arm that is on the fuel pump. And there is a block off plate there.
Plowking
  • Turtle Points: -75
  • Male Posts: 504
  • Member since Jan '05
  • Awesome yota
    • Buy me a drink
« Reply #3 on: Jun 01, 2006, 08:24:58 PM »
As far as I know the lever for the pump sits right on a metal collar that bolts on behind the upper timing gear as long as you have a plastic spacer between the fuel pump and the head you should be good go. Go to http:www.parts america.com  and enter the desired info
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
Last post Mar 31, 2005, 07:34:15 PM
by alwayzbroken
Last post Apr 08, 2006, 05:00:50 AM
by Johnny5
Last post Nov 07, 2009, 04:24:15 PM
by 83yota
Last post Dec 01, 2009, 01:42:50 PM
by drayday55
Last post Oct 04, 2011, 01:51:35 PM
by 69800
