No, you will need the engine also, see the sticky up top,read,learn,ask.
Is just the engine wiring harness enough wiring to do the swap? thanks for the help
If you live in California you will also have to swap in the evap system of the donor vehicle. Dont' forget about the alternator, p/s pump, a/c compressor, bellhousing, flywheel and clutch - not to mention the minor fab work you will need to do on the motor mounts and various other things.
Started by Plowking Toyota Pickup/4Runner Tech 1979-95
Started by zippo Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by 4RunnerChevy Engine
Started by crazymoritz97 Engine
Started by crazymoritz97 General 4WD Discussion
