Author Topic: Dumb rear axle ?  (Read 1879 times)
Vic stuff
  • Turtle Points: 52
  • Male Posts: 172
  • Member since Jan '06
  • Damn it feels good to be a gangsta.
    • XT Offroad
Dumb rear axle ?
« on: May 21, 2006, 07:24:44 PM »
ok dumb rear axle ?. i need to change my rear outer seals, but are the toyota shafts pressed into the bearings (like a dana axle) or will be able to disassemble the drums and pull the shafts out to change the seals?  TIA!
84 4Runner - 37's, Locked F/R, 4:1 (single), Cab exo, new front bumper and some more tubage coming soon! Currently parked with a blown motor :(
05 Explorer - The Wife Mobile
04 Chevy Silverado - Towrig/DD
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
Re: Dumb rear axle ?
« Reply #1 on: May 21, 2006, 08:14:14 PM »
pressed with a keeper behind.
Vic stuff [OP]
  • Turtle Points: 52
  • Male Posts: 172
    • XT Offroad
« Reply #2 on: May 21, 2006, 08:30:34 PM »
so do i need to get the bearing pulled and pressed back on to change my seals?
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
  • So many yoda's, so little time!
« Reply #3 on: May 21, 2006, 09:32:18 PM »
I thought that the rear axle seals went in the end of the housing???  Pull the shaft, get the seal out, and put the new one in?
PZ
92 xtra cab, with some stuff...
...why buy when you can build?
reklund5
  • Turtle Points: 286
  • Male Posts: 1,263
  • Member since Nov '03
  • I love my Marlin Crawler!
« Reply #4 on: May 21, 2006, 09:42:18 PM »
Theres two seals in there, but the "inner" of the two is the one that usually goes bad.
Disconnect the ebrake cable from the backing plate.
Disconnect the brake hardline from the backing plate.
Remove the 4 14mm bolts from the backing plate at the axle flange.
Pull the entire backing plate/axle assy out of the housing.
The seal is in the end of the housing and easily replaced now.  Reverse for re-assembly.
Ryan
Vic stuff [OP]
  • Turtle Points: 52
  • Male Posts: 172
    • XT Offroad
« Reply #5 on: May 21, 2006, 09:46:10 PM »
the inner seal on the axle as in behind my third inner? thx for the other info though!
Ryan
reklund5
  • Male Posts: 1,263
« Reply #6 on: May 21, 2006, 09:55:11 PM »
No, not behind the third...sorry to confuse you.
Theres one that's more of a dust seal that gets installed before you press together the axle/backing plate assy., and one that is in the end of the housing.  The one in the end of the housing is the "inner" seal, as the other one is in the bearing retainer the goes in the backing plate, more to the "outer" side of things.
Its right there in the end of the axle housing-  you'll see it easily when you pull the backing plate/axle assy. out.
Ryan   :beerchug:
Vic stuff [OP]
  • Turtle Points: 52
  • Male Posts: 172
    • XT Offroad
« Reply #7 on: May 21, 2006, 10:52:45 PM »
so when i go get the seal at the parts store its the inner seal then technically?  and i assume, from the way it sounds as if the bearings slides inside of the seal?  thx for the help, toy axles are new news to me, personally use to dana type axles
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
« Reply #8 on: May 21, 2006, 11:36:10 PM »
yep, it's the inner.  the seal lip rides the axle shaft to keep gear oil from leaking out of the housing and washing out the grease from the bearings.  the bearing itself is a big sealed unit that's pressed onto the shaft.
Last post Dec 29, 2003, 07:52:11 AM
by Duckman
Last post Sep 21, 2005, 12:41:02 AM
by Makohon
Last post Feb 01, 2006, 06:01:11 PM
by Loosekannon
Last post Jun 20, 2020, 03:10:03 AM
by Gnarly4X
Last post Nov 24, 2022, 12:54:48 PM
by OVRAROK
