Author Topic: motor sputter  (Read 3129 times)
ROLIE POLIE
  • Member since Feb '06
motor sputter
« on: May 15, 2006, 09:10:38 AM »
 :help:
 i have a 1987 toyota 4 runner with a slightly modified 22re
(bored, cam ,k&n air filter(air box style) header, muffler)
the problem im having is it hesitates(right in my cruse range) between 2,000 & 3000 rpm, but once it reaches around 3100 rpm it jumps right out of it and runs like a top above 3000,  i drive down a moderatly steep hill every day and once i get to the bottom it sputters in that same rpm range in 1st and 2nd gear, then after playing with the skinny peddel a little it pops right out
the truck revs up jus fine out of gear, it smells a little lean. ive tried testing the following parts, : coil/igniter,afm, and im gunna try a different distributer today, it dose have a header leak right above the o2 sensor might that have anything to do with it?         any info could help
« Last Edit: May 15, 2006, 09:19:48 AM by ROLIE POLIE »
BobJ
  • Turtle Points: 104
  • Male Posts: 37
  • Member since Jul '05
Re: motor sputter
« Reply #1 on: Sep 25, 2006, 10:19:45 PM »
Curious what lean smells like? Have you tried richening the air metering valve settings at all?
Knute
  • Male Posts: 67
  • Member since Dec '07
  • 12runner
Re: motor sputter
« Reply #2 on: Mar 20, 2008, 11:15:46 PM »
 if there is a rip in your intake boot, that will do it even if its really small
it happened to me, and it was just a little 1inch rip in the boot.
Knute
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: motor sputter
« Reply #3 on: Mar 21, 2008, 12:01:41 AM »
O2 sensor
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
NATER623
  • Male Posts: 34
  • Member since Jun '09
Re: motor sputter
« Reply #4 on: Jul 15, 2009, 08:58:11 PM »
you may have a funky TPS with a bad spot or a funky AFM with a bad spot or the door is not moving freely.     Like Knute said, take a good look at the intake tube and rubbers.  The curved one at the throttle body cracks down between the pleats.  Mine has a crack, I put a RTV silicon band-aid on it till I find a good one.
EDIT: sorry to drag an ancient thread to the top   :hammerhead:
« Last Edit: Jul 15, 2009, 09:17:32 PM by NATER623 »
MR2 Motor
Last post May 03, 2004, 09:26:56 AM
by Celerity
Last post Nov 23, 2007, 07:52:48 AM
by JCHJ
Last post Jul 19, 2009, 02:23:15 PM
by Tim
Last post Feb 21, 2011, 11:53:34 PM
by yotaneck13
Last post Oct 23, 2017, 06:00:54 AM
by redneckcustoms13
