Author Topic: Help.... what axle do i have????  (Read 813 times)
brad091703
  • Member since Nov '05
« on: May 05, 2006, 08:02:07 AM »
Hey i see on Aussies page its only says for 30spline axles? dont i have the 27 sp.  I have an 84 yota 4cyl.  Thanks guys
derek
  • Turtle Points: -61
  • Male Posts: 600
  • slow truck=more time to nap
Re: Help.... what axle do i have????
« Reply #1 on: May 05, 2006, 08:21:27 AM »
 ??? all toyota axles are 30 spline inner and outers. the only part that is 27 spline is where the axle goes into the birfield. this is what has been upgraded by bobby long to 30 spline.
this is for a toyota solid front axle. toy rears are also 30 spline where they go into the third.
brad091703 [OP]
« Reply #2 on: May 05, 2006, 08:29:38 AM »
really?? i c, now what is the deal with the 6cyl drop outs? whats better?
derek
  • Male Posts: 600
« Reply #3 on: May 05, 2006, 09:10:50 AM »
V-6 rear thirds are the same (will bolt right into a 4cyl housing). they have slightly larger bearings and a little bigger pinion gear and the carrier is a different design and the third its self is beefier with more ribs on it than the 4 cyl. you can even fit 4 cyl gears in the v-6 third with a ring gear spacer and with the right combo of bearings you can fit v-6 gears into a 4 cyl housing.
Last post Dec 29, 2003, 07:52:11 AM
by Duckman
Last post Nov 26, 2004, 04:36:37 PM
by jvministries
Last post Dec 13, 2005, 10:19:37 PM
by DRM
Last post Mar 07, 2006, 12:59:13 PM
by robinhood4x4
Last post Mar 03, 2006, 05:44:55 PM
by KYOTA
