Author Topic: rear axle leak  (Read 2668 times)
81yota
  • Male Posts: 56
  • Member since Jan '05
rear axle leak
« on: May 03, 2006, 12:41:55 PM »
after swapping in my new 3rds, my driverside rear axle leaks bad. Looks like the leak is coming from under the drum area. What exact seals do I need? (Inner axle seal, Outer seal, Bearing?)
81yota
Locked F/R
39 TSL'S
5.29's
Dual Cases
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
Re: rear axle leak
« Reply #1 on: May 03, 2006, 01:01:04 PM »
Sounds like the seal that's pressed into the end of the axle housing.   It might have been damaged during the swap.  You have to be real carefull sliding the axle shaft's in or out, not letting the weight of them rest on the seal.  They are not very expensive.  Hope this helps.
:thumbs:
I like to Drive!
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,058
  • Member since Dec '03
  • Crawlin with Marlin
Re: rear axle leak
« Reply #2 on: May 03, 2006, 01:04:26 PM »
I would agree and they are fairly easy to fix and inexpensive.
81yota [OP]
  • Male Posts: 56
Re: rear axle leak
« Reply #3 on: May 03, 2006, 01:09:34 PM »
so its the outer axle seal then?
81yota
Locked F/R
39 TSL'S
5.29's
Dual Cases
Earlyota
  • Male Posts: 23
  • Member since Apr '06
  • "Earlyotas" --- 79-83's RULE!!!
Re: rear axle leak
« Reply #4 on: May 03, 2006, 01:45:29 PM »
yes, more than likely.  as mentioned above, you really have to be careful when pulling your axle shafts not to disturb that seal.  either way, sometimes they 'just leak'.  i have torn apart dozens and dozens of Toyota rear axles....and even with all the proper pre-cautions and steps taken, sometimes it'll just happen
NOT an expensive fix or hard problem to solve though.....
1983 Toyota 4x4 P/U, short bed, 3" Custom ALCAN front springs...they make 104" Wheelbase, 2" Rancho-cheapie rear springs with 1" machine-shop fabricated shackles, 31's on 15x8 AR Outlaw I's, square front driveshaft. New CARB., fuel pump, exhaust. 120K original miles!!!  Bed has little rust!!
Mnmstoy
  • Turtle Points: 50
  • Male Posts: 230
  • Member since Feb '05
  • Mike's 80Toy
Re: rear axle leak
« Reply #5 on: May 03, 2006, 02:10:57 PM »
IS the parts number for AutoZone
Goes in here.
Mike
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
Re: rear axle leak
« Reply #6 on: May 03, 2006, 02:30:47 PM »
Goes in here.
Mike
That's the one I was talking about. :yesnod:    I just couldn't remember what is was called. (Inner, or Outer)
I like to Drive!
81yota [OP]
  • Male Posts: 56
Re: rear axle leak
« Reply #7 on: May 03, 2006, 02:46:01 PM »
hopefully this will fix the problem...filling up with gear oil everyday is a pain in the ass.  :yikes:
81yota
Locked F/R
39 TSL'S
5.29's
Dual Cases
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
  • So many yoda's, so little time!
Re: rear axle leak
« Reply #8 on: May 03, 2006, 04:19:44 PM »
and stinky!
92 xtra cab, with some stuff...
...why buy when you can build?
eightyfive
  • Turtle Points: 232
  • Male Posts: 552
  • Member since Dec '05
Re: rear axle leak
« Reply #9 on: May 03, 2006, 05:50:36 PM »
leaking oil from the seal shouldn't empty out all your gear oil....you can drive with a leaky seal for a long long long time and still have oil in the diff.
._________________________________________.
||____________||____________||___T0Y0TA__||
||____________||____________||____________||
1985 TOYOTA 4RUNNER
some modifications here and there....
81yota [OP]
  • Male Posts: 56
Re: rear axle leak
« Reply #10 on: May 03, 2006, 06:05:47 PM »
yeah when I look in the diff, I can still see alot of diff fluid and when i refill it barely takes a few squeezes and it starts to leak from the filler nut. I just dont wanna waste burning up my new gears.
81yota
Locked F/R
39 TSL'S
5.29's
Dual Cases
RHG
  • Male Posts: 1,320
  • Member since Apr '05
  • WERD!
Re: rear axle leak
« Reply #11 on: May 04, 2006, 06:23:27 AM »
Haha I have the same problem, I was actually worried that I tore up a bearing but I guess those seals are pretty sensitive. They are only like 8 bucks from Kragen. I just have to get around to changing it. Been leaking oil for a while now. Maybe that will be my chore for today.
eightyfive
  • Male Posts: 552
Re: rear axle leak
« Reply #12 on: May 04, 2006, 05:27:40 PM »
i say, if posssible, wait until you can get a hold of a IFS rear axle that doesn't leak. then just swap axles. that's what i did. drove on my leaky axle seal for over 3 years without topping it off once. now it's time to upgrade to the IFS which will give me NO leaky seals! 2 birds with one stone. oh, since i'll have to disconnect the brake lines...im upgrading to the 26" lines while im at it. oh, and i found a 17gal gas tank too. and since i have to drop the gas tank to disconnect the ebrake cable to do the swap, i throwing that in too....4 birds total.
1985 TOYOTA 4RUNNER
Last post Dec 29, 2003, 07:52:11 AM
by Duckman
Last post May 05, 2006, 10:30:08 AM
by andy_547
Last post Jul 25, 2006, 06:51:11 PM
by boggerunner
Last post Aug 05, 2006, 02:45:05 PM
by i_luv_my_truck
Last post Dec 04, 2007, 08:51:29 PM
by Plekto
