Author Topic: White and yellow under oil cap.....  (Read 2580 times)
vaj70cruiser
  • Male Posts: 609
  • Member since Apr '05
  • marlin ultimate crawler
« on: Apr 13, 2006, 05:50:44 PM »
i was thinking the head gasket gave up...??
Fj40 V8 efi ss350 marlin ultimate crawler 290:1
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: White and yellow under oil cap.....
« Reply #1 on: Apr 13, 2006, 06:27:04 PM »
Head gasket usually looks like a chocalate milkshake.
wa4x4
  • Turtle Points: -310
  • Male Posts: 1,569
  • Member since Jul '05
  • I'm about to tear the curb up
« Reply #2 on: Apr 13, 2006, 07:25:42 PM »
White and yellow, like the residue around the cap or down inside the motor?
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
« Reply #3 on: Apr 13, 2006, 07:59:42 PM »
its definitely water/coolant in yer engine.  HG, or timing cover.  Either way, it's time for a teardown.
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
« Reply #4 on: Apr 13, 2006, 09:57:19 PM »
What year is your truck? Probably head gasket, but some of those timing covers would get electrolisys and eat a hole through the back of the timing cover and the water pump will puke coolant into the crank case. "If" that's the case you just need to replace the timing cover, otherwise it's head gasket time.
(and yes, you can replace the timing cover without pulling the head, but it's tricky)
eightyfive
  • Turtle Points: 232
  • Male Posts: 552
  • Member since Dec '05
« Reply #5 on: Apr 14, 2006, 01:32:47 AM »
not tricky at all, just drop the oil pan instead of pulling the head....make sure your very nice with the ATV sealant stuff.
yellow oil cap, you have water mixed with oil in the engine....that is not good. fix it before you hydro lock the b*tch
1985 TOYOTA 4RUNNER
Prismo
  • Turtle Points: 8555
  • Member since Oct '03
  • Living in the green house
« Reply #6 on: Apr 14, 2006, 01:59:24 AM »
Might consider doing the crank bearings at the same time. I blew a head gasket, same water in the oil. Had a rod knock 3 months after I fixed the head gasket.
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #7 on: Apr 14, 2006, 07:37:59 AM »
Run a compression test to see if it is the head gasket. Otherwise, if this is a 4cyl R-engine, then it will be the front timing cover because the guides were not replaced after they wore out and the timing chain has gone right through the housing and into the water port.
Moisture in the crank case will produce a white mayonnaise substance on the cap.
I am not sure about the yellow coloring. Must be rust or something...... :headscratch:
vaj70cruiser [OP]
  • Male Posts: 609
« Reply #8 on: Apr 14, 2006, 10:18:51 PM »
if i would to change the head gasket, i'd thinking of doing a complete engine rebuilt... anyone know any good sites for quality 22re rebuilt kit??? any other then LC engineering...
wa4x4
  • Male Posts: 1,569
« Reply #9 on: Apr 14, 2006, 10:26:03 PM »
www.engnbldr.com
/\Good stuff.
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
« Reply #10 on: Apr 14, 2006, 11:52:13 PM »
www.engnbldr.com
/\Good stuff.
X2
Thats what I rebuilt my engine with, and it great!
Last post Nov 17, 2005, 06:56:12 PM
by Crawler677
Last post Jun 01, 2006, 01:18:21 PM
by alpha_radiation
Last post Jul 05, 2013, 08:29:52 AM
by BirdDog
Last post Jul 28, 2013, 10:37:06 AM
by 85-4roller
Last post Sep 29, 2014, 07:05:28 PM
by spuds015
