What year is your truck? Probably head gasket, but some of those timing covers would get electrolisys and eat a hole through the back of the timing cover and the water pump will puke coolant into the crank case. "If" that's the case you just need to replace the timing cover, otherwise it's head gasket time.(and yes, you can replace the timing cover without pulling the head, but it's tricky)
www.engnbldr.com/\Good stuff.
...why buy when you can build?
Started by moutaintoys Stolen Rigs and Theft!!
Started by corrupt Toyota Pickup/4Runner Tech 1979-95
Started by 85-4roller Trails & Land Use
Started by Hurricaneinmotion Project Research and Build-Ups
