Author Topic: Minor swap questions...  (Read 1635 times)
vikingsven
  • Turtle Points: 144
  • Member since Jul '02
« on: Oct 27, 2003, 08:28:13 AM »
I'm getting my Turbo Tranny Swap ready and need to sort out some minor details...
1)Is there any difference in the starters used on early (pre- 89) toyotas and those used on later models? Specifically, is a different starter needed on later 22RE trucks with the larger flywheel, or are they all the same as far as 4 cylinders go?  :hammer:
2) Will my clutch slave work in the swap or do I need a different model/year???. I have an 88 pickup with a W56.
Thanks... :beerchug:
« Last Edit: Oct 27, 2003, 08:36:23 AM by vikingsven »
cancel
  • Member since Aug '05
Re: Minor swap questions...
« Reply #1 on: Dec 07, 2005, 09:19:15 PM »
get any info on this... i'm doing the same swap and i'm in the need of the same info
CruzrDave
  • Administrator
  • Turtle Points: 441
  • Male Posts: 4,631
« Reply #2 on: Dec 12, 2005, 10:39:38 AM »
The ring gear is the same size and tooth count  between the 8-7/8 and the 9-5/16 flywheels. The starters will bolt on. I'm not sure in the wires to the starter are the same conectors through the years.  Your clutch slave will work just fine, there is one slave used from 81-95.
Taking back America, one part at a time! :madeinusa:
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
« Reply #3 on: Dec 14, 2005, 10:22:23 AM »
aren't the flywheels exactly the same other than the machined step on them?
Last post Jul 24, 2005, 08:16:49 PM
by brainlessfool
Last post Nov 17, 2005, 06:53:53 PM
by h0nke
Last post Dec 14, 2005, 08:32:16 PM
by Ramrod
Last post Feb 16, 2006, 12:54:06 PM
by 79coyotefrg
Last post May 23, 2006, 01:05:27 PM
by mntgoat
