Author Topic: Vibrating T-Case  (Read 1164 times)
90slvpup
  • Turtle Points: 135
  • Member since Feb '05
Vibrating T-Case
« on: Feb 23, 2006, 07:50:24 PM »
Well i just finished swaping in my new toyota front end with longfields :bling:.  The truck is sweet now but something has started to vibrate... :rivers:   We used a long slip front drive shaft... now whenever the hubs are locked the truck has a slight vibration and when 4 wheel drive is in (transfercase in 4WD) the vibration is extreme especially after 30 mph,  at first the shop i took it too thought it was the bearings but now they think it is the driveshaft vibrating how can i tell for sure if it is bearings or the drive shaft?  Thanks for the help
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: Vibrating T-Case
« Reply #1 on: Feb 23, 2006, 07:53:17 PM »
Make sure your u-joints are in phase, the clips should be all facing the same way.
Did you change your suspension at all?
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
« Reply #2 on: Feb 24, 2006, 08:10:17 AM »
Does your new front drive shaft have a CV or did the drive shaft shop only put regular u joints at each end. I know it's worked for some people, but everyone i've known who got a dshaft without the
CV has had the same vib probs.
derek
  • Turtle Points: -61
  • Male Posts: 600
  • slow truck=more time to nap
« Reply #3 on: Feb 24, 2006, 08:17:21 AM »
pull the front shaft and drive it with the hubs locked and in 4wd. that will let you know if it is the front shaft or not.
derek
Last post Nov 20, 2005, 05:19:12 PM
by Marlin
Last post Jan 02, 2006, 10:14:37 AM
by Rocksurfer
Last post Mar 02, 2006, 11:08:54 PM
by toysfreak
Last post Apr 24, 2012, 05:54:28 PM
by Nimyad
Last post Jul 24, 2013, 08:53:06 AM
by porkchop_88
