Author Topic: strange noise  (Read 2213 times)
DAWGTOY
  • Turtle Points: 460
  • Male Posts: 212
  • Member since Jul '04
  • aint too old & broke up to sit down yet
strange noise
« on: Feb 21, 2006, 07:13:25 AM »
hey guys gots a ? for yall.
 on my 83 with an 86 rear housing 99 elocker center section 5.29 gears.
anytime the truck is rolling i hear a bump bump bump coming from
the rear. when i jack up the truck and turn the axle by hand you can't
hear it. when you run the truck in gear you can't hear it. only when
it's on the ground rolling can you hear it. there is a dent in my housing
that the carrier may be hitting on. that may be it. it don't sound like a axle
bearing. i just hope it's not my ring & pinion cause i'm goin off to ride this weekend.
gonna pull the diff this afternoon & take a look see. :crossed:
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: strange noise
« Reply #1 on: Feb 21, 2006, 07:26:49 AM »
This same senario occured in Moab to a friend., as he was driving you could hear a distinct thunking coming from the rear but if you jacked up the truck and just spin a wheel nothing. So now for the bad news, he had a couple chunks missing out of his ring gear. Sorry hope that helps.
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: strange noise
« Reply #2 on: Feb 21, 2006, 09:36:20 PM »
Ditto, happened to me twice...maybe 3 times.  It was helacious at anything above 25-30 mph, but on the jack you couldn't hear a thing.  We noticed the pinion flange was flopping up and down a lot cause I had broken 10 pinion teeth half off.
DAWGTOY [OP]
  • Male Posts: 212
Re: strange noise
« Reply #3 on: Feb 22, 2006, 07:19:53 AM »
good news " its only a flesh wound" :thumbs:  ( in best monty python voice).
pulled the axles in order to pull the center and found my
drivers side axle bearing about to fall off. :yikes:  very worn out.
gots my new parts this morning and puttin back togather
tonite. :clap:
 thanks for the replys guys. :beer:
dawg
 :turtle:  :turtle:  :turtle:
  • Momentum Man
  • Lego Enforcement
Re: strange noise
« Reply #4 on: Feb 22, 2006, 07:25:02 AM »
tonite. :clap:
dawg
Lucky!
Good to hear it turned out to be something small.
Plowking
  • Turtle Points: -75
  • Male Posts: 504
  • Member since Jan '05
  • Awesome yota
    • Buy me a drink
Re: strange noise
« Reply #5 on: Feb 23, 2006, 06:51:45 PM »
The gear oil on the tire of the offending axle usually is a sign. Been there as well.
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
SQUIRREL MONSTER
  • Turtle Points: 151
  • Male Posts: 657
  • Member since Jul '05
  • squirrel powered by hampsterous oxide!
Re: strange noise
« Reply #6 on: Feb 23, 2006, 08:58:56 PM »
hmm, im getting a very weird grinding noise from the rear and is also starting to seep oil from one of the axle seals. could this be a similar condition of the same problem?
DAWGTOY [OP]
  • Male Posts: 212
Re: strange noise
« Reply #7 on: Feb 24, 2006, 06:56:53 AM »
yea gear oil on the tire would have been a dead giveaway. :headscratch:
but there was none. the seal was doing a good job of
holding it back i guess. :yesnod:
 replaced both bearings and inner and outer seals.
tested it out and everythings golden. :thumbs:
 i guess those deep water crossings got to them after all. :ha_ha:
 thanx for all the input. marlins a great board to be on. :turtle:  :turtle:  :turtle:
dawg
ps them bearings are a pregnant dog to remove. :shocking:
Last post Aug 13, 2003, 02:38:46 AM
by mr4x42u
Last post May 16, 2005, 12:22:36 PM
by Volcom
Last post Jul 25, 2008, 06:34:02 AM
by OOPS
Last post Jun 27, 2019, 10:49:08 AM
by *FFC*
Last post Jul 22, 2019, 09:10:56 AM
by Lewis Hein
