uh why, if you want more room between the tires and frame then get a 86+ rear axle so you have a touch wider stance
Because it would be the same as inboarding your springs for better flex, and would solve clearance issues at the same time. Then it would make it possible to add shocks on the outside of the frame, like the front, making it real stable.I was thinking of doing the same deal. Chop the frame a couple inches past the cab. Narrow the rear section to the same width as the front. Span a 2x4 square tubing across the frame stubbies behind the cab. Measure and weld the rear section back up as close to center as possible. Cut the middle section of the square tubing so its flush. Use that square tubing to gusset it, inside and outside of the narrowed rail. Cut your spring perches and weld new ones to new specs.You'd have to of course scrap the box and build a flat bed. And mount the gas tank up top. Reroute the brake lines & gas lines. Not too much work. Definitely possible...Am I totally out to lunch?
Yeah, I laughed my behind off when i first saw it. It's pretty good.
Only all the kids with SAS's and bobbed beds are getting the 86+ axles just because everyone else is doing it... you know, so they don't rub their tires on their frame rails when they go down the fireroad to do that poser shot on a tree stump. Glen
[Thread Hijack] I've got a question for you Burn,How much rise are in those 4x4lab arms (from top of mounting point to top of arm)?I designed a similar set of arms and am milling them right now, but I've never seen 4x4labs arms in person before and I was just wondering if how much rise they put behind the axle.Thanks[/Thread Hijack]
thats cool that we are doing the same thing synwars, keep me posted on what your doing. I will plate the bends (more than likely) and looking at doing 22.5deg to get my 45's
syn, got some pics of yur truck? and have you started on yer narrowing?
why does everybody want hydro assist
Started by mitchell « 1 2 » Project Research and Build-Ups
Started by 85 4runr « 1 2 3 » Project Research and Build-Ups
Started by scarboy « 1 2 » Project Research and Build-Ups
Started by Jud « 1 2 ... 23 24 » Project Research and Build-Ups
Started by *** YELLER *** « 1 2 ... 15 16 » Project Research and Build-Ups
