Author Topic: Skyjacker Shocks, running 4 rears?  (Read 1777 times)
yoter
  • Member since Jan '06
« on: Feb 08, 2006, 02:03:57 PM »
Im building on the cheap so I was lookin at some shocks. I found some Skyjackers for $40 at the local parts place. Its for there 7"-8" lift. Im gonna run 5-6" of lift but heres the specs:
The Fronts: 14.5" Compressed/ 24 3/4" Expanded
The Rears:  17.3" Compressed/ 29 3/4" Expanded
The question is can I run rears on all 4's to keep the front flexin, and not hangin me short on flex?
Or do you guys think it will be ok?
yoter [OP]
Re: Skyjacker Shocks, running 4 rears?
« Reply #1 on: Feb 09, 2006, 06:27:33 AM »
Are skyjackers shocks very good to run anyways?
TNToy
  • Turtle Points: 7
  • Member since Oct '02
  • <-- This End Up
    • Just a Webpage...
« Reply #2 on: Feb 09, 2006, 07:28:11 AM »
Those are fairly long shocks. Especialy the rears. The fronts are similar in lengths to a 9012 or 5012 rancho.
There's only one way to know. Flex your truck with no shocks, and MEASURE for yourself on both sides, front and rear. Boom. You now know if they'll bottom or top-out on you.
yoter [OP]
« Reply #3 on: Feb 09, 2006, 08:12:24 AM »
I am trying to get Close to the bilisten 12"?
whiteman
  • Turtle Points: 669
  • Male Posts: 1,276
  • Member since Jan '05
    • Buy me a cigar
« Reply #4 on: Feb 09, 2006, 08:22:59 AM »
What lift you are going to use will determin whether or not you want to use those shocks.  If you use askyjacker, superlift, Rancho, Tuff country, etc..   You should be able to use those shocks, however if you go with a Marlin , All pro , Alcan, or use your rear springs up front you may not want those shocks due to the limited travel.
Those in reallity are actually pretty small, most guy's start woth a 14" travel shock and end go up from there.
But exactly whta you said is true
Quote
Quote
yoter [OP]
« Reply #5 on: Feb 09, 2006, 10:40:10 AM »
Yeah I am gonna run rears up front, and chevys out back?
whiteman
  • Male Posts: 1,276
    • Buy me a cigar
« Reply #6 on: Feb 09, 2006, 03:17:53 PM »
You may want to look into longer shocks then.
Unless you mount them at the proper angle, but then that reduces the effectiveness of the shock.
yoter [OP]
« Reply #7 on: Feb 10, 2006, 06:08:44 AM »
Truely I am not gonna be a super flexy rock crawler. I might at must pull up on a buddies tire and flex, on solid ground. Mainly wantin the rears to be on the ground.
Last post Feb 27, 2006, 05:40:27 PM
by eightyfive
Last post Jul 02, 2009, 05:32:54 PM
by 86rustbucket
Last post Nov 28, 2005, 07:54:58 PM
by KYOTA
Last post Aug 17, 2006, 07:26:26 PM
by AlaskaToy
Last post Sep 09, 2007, 07:16:48 PM
by slabcrawler
