BOGGERS VS IROKS ?
Started by Thumper, January 22, 2006, 12:38:10 PM
Birfailed
That sawzall idea is genius!
Go 1-Ton from the start
newbe94
thanks guys do you think it would help out with the 38.5?
MiniSimp
Probably just me driving more agressive, but....I have broken 3 birfs on my 37 Iroks, none on my 35 boggers. The 35 boggers weighed way more than my 37 iroks so I may just be hammering the skinny more than I should.
porkchop
Quote from: MiniSimp on December 22, 2008, 01:29:33 PM
Buy Longfeilds and do not worry about skinny pedal
85 TRUCK AUSSIE IN FRONT LINCON AROUND BACK MARLIN 4" SPRINGS UP FRONT WITH 63 CHEVYS ON BACK. REBUILT 22R WITH CRAWL CAM AND FEW OTHER THINGS NOTHING HUGE JUST WAITING TO GET PROPANE ON IT. RUNNIN 35'S M/T WITH MY LONGFIELDS 30 SPLINE SUPER AXLES. 4.7's IN T-CASE AND ON THE WAY WITH DUAL CASES. FULL HYDRO WITH TG ROCK ASSULT PUMP AND 2 X 6 AG RAM
Monster Yota
Quote from: furrballs95 link=topic=19981.msg#msg date=
wats going to last longer a swamper SX or an irok
I would think the SX because it has more rubber surface to the ground, much bigger lugs!  All I know is I love my SX's, and couldnt be happier. They will be what I buy again, unless I happen to get a good deal on 38.5 Boggers!   :gap:
MARLIN 4 PRESIDENT!
MiniSimp
Quote from: porkchop on December 29, 2008, 08:50:38 PM
How about you buy them for me? :eyebrow:
newbe94
can you buy me a set too  :thumbs:
porkchop
sure  got  a set for both of guys
subliminaltrips
i went from sx's to iroks and i will say that the iroks air down alot better and seem to hook up better. the sx's were great tires though a good all around mud/crawling tire.
diggo
Do looks count?? If so BOGGERS all the way. You are in mud, come on, BOGGERS! you know they must be better in mud! they are called BOGGERS. Right? 6 in one hand and 1/2 dozen in the other. What do I know I live in sothern AZ we dont have mud. Got sand? :dunno:
Drive it like you stole it!   I like jeeps! Every hot chick should have one!
80_yota_pickup
in my opinion iroks are the way but only work good if they are aired down to 10 or less with locks and they would wear in the middle real bad aired up on the black top but that if you have bias. and unless you run in the soupy mud then i think both the bogger and irok are comparable
SAY i WON't... AND i WILL
80 pickup SB with 87 4runner SR5 interior,22re swap, welded F&R, 5" allpro springs, ultimate duals, 36" iroks, DIY beadlocks,SB bobbed 16",
coming next: full cage, longfields, and 5.29's
