I also suggest getting rid of the paporioning valve at the rear and using an adjustable one, factorty ones like to get internal leaks that suck air but dont leak fluid.
The actual correct bleeding order is -RRLRRFLFLSPV
Sounds like air in the lines.Bleed in this order:Left rearRight RearLSPV (Load Sensing Proportioning Valve)Right FrontLeft FrontIt might take 3 cycles to get all the air out, keep an eye on your fluid level when you bleed also.
ah cool! so where does the BPV fall into this order? shouldnt it be bled through the process of bleeding the rear?
BPV? are you talking about the LPSV? Load Proportioning Sensing Valve
BPV=brake proportioning valve
Started by trax28to Parts For Sale
Started by sjdeas87 « 1 2 » Parts For Sale
Started by Joe S. Toyota Pickup/4Runner Tech 1979-95
Started by NaturalDisaster Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by i_luv_my_truck 1979-1983: How-To Guides
