I remember once you let me drive it ................. ok it was like a whole 15ft but it was :haven:
Joe should come out this year again.
That's a Jeep setup. I believe the design concept is that the axle gets pushed forward under compression rather than back (i.e. it pushes against the bump).I think a reversed shackle is something different because they do it on Blazers and I've never seen a Blazer with a shackle on the front.
Thanks bd I've heard that jeeps are doing away with the setup and going with the shackle in the rear. Looking for indications why they'd be doing this - what to avoid basically.
One advantage is the axle moves rearward as it droops which minimizes the length change in the front driveshaft. Less likely to seperate a shaft at full droop.The only bad thing is the ride is rougher (as mentioned by the bump theory) and the handling can pretty much suck on the road with any sorta worn parts especially more with a short wheel base vehicle. I think this is the primary reason most jeep guys do a shackle reversal. Personally, I would prefer to have the shackles in the rear of the spring.
You're welcome J. If you already have all the stuff and it's just a matter of bolting it up...why not try the front mounted shackle to see if it will suffice for the trip? If it doesn't work to yer liking then you will know for sure if you need to commit to the other work necessary to get what you're looking for. Hope you get this done before the last minute...
Sorry to hear about Matt's aunt... Give Matt a for me.Yeah, I like to see which way you go with this. Sounds interesting. I just hope whatever you go with, it's something that can be done in time and will work for ya and certainly hope it won't cause you any trouble on the trail.
Another idea: How bout if I take my leaf pack apart and put a new hole in the main, say like 2 inches forward - then put it all back together. I would think that would make it weaker at the ubolts, and it seems like I'd be busting centerpins all day long. Anyone ever do this?
Ever try drilling into spring steel? It's not easy. What about redrilling the spring perch? Is that doable on yours?
Someone else mentioned having a new main actually made custom......
I don't have 2" worth on the perch. I can probably go a half inch or so, but I don't see that being much of a benefit for the work involved.
It could be done. but is it cost effective? 2" is a lot but what about the steering box? Is it far enough forward to move the axle that much or will you have to relocate it?
Sounds like you got a good buncha work ahead of you...better get to or else...
That's pretty much what I was saying earlier. At least to get you through this run and then fix it afterwards.
Hey back to the shackels. you are thinking about putting the shackels up front of rhe spring in the front like the older jeeps or the other way around? If so the only thing i have heard bad about it is, if the shcackles are longer and while wheeling you run one of the shackles into a rock it could bend the springs and ruin them. Heppened to a guy i know in his jeep just got to look out for that.
Started by DTB General 4WD Discussion
Started by rmoore Toyota Pickup/4Runner Tech 1979-95
Started by Shamb Chit Chat Camp
Started by bng1 Parts Wanted
Started by Eschenfeldt New Member Check-In!
