0 Members and 30 Guests are viewing this topic.
My brain is now smoking...
I did put in an extra ground from the head to the fender well a while back and it made no difference.
On the MAF, originally I had a Toyota one, then I replaced it with a remaned one and it ran better but still has issues. With the stick MAF it was beginning to dog out at like 2800 rpm, the remaned one I can get 3500+/- before it dogs out. My parts guy ordered me up another one to test and still no difference......
Took a drive just now with the scan tool. Long term fuel trim is like 15-17% at idle and from 25% to 37% while getting on it....Is it possible with that cone I am just getting too much air for the ECU to compensate for?...I know the turbo/tuner set uses RX7 injectors that are a direct fit but like 440cc. Should I consider this route?
Maybe I have a nasty injector?
Also, how smooth is your idle and have you ever ran a compression check?
Started a new job as the dreaded tax assessor so I haven't had time to do anything. I will pull those plugs soon...
I really want to do this swap, but I'm having a hell of a time tracking down a motor. Much less a motor with everything required and from a manual vehicle. Anyone have any suggestions?
Hey BigMike. I'm here in Fresno. Do you guys ever do these swaps for people? What would a service like that cost? Just wondering. Thanks again for the input.
Orrrr.....you could give a 2TR swap a go? Looking at car-parts.com, they're actually slightly cheaper than the 3rz's. Weird. No idea if it would be cheaper overall for everything needed though. Probably not because I don't think my W56 would mate to a 2TR in any way.
OK so I got my engine issue resolved, it was a plugged fuel line. I know that the three RZ sits at 10 degrees at the valve cover off level ,but is it normal for the transmission and transfer case to sit at an angle?
Started by cruzila « 1 2 ... 32 33 » Rig Gallery
Started by yotaboy79 « 1 2 ... 32 33 » Chit Chat Camp
Started by BLACKDOG « 1 2 ... 11 12 » Chit Chat Camp
Started by Willy Mammoth « 1 2 3 4 5 » Chit Chat Camp
Started by Rocksurfer Chit Chat Camp
