Author Topic: power steering cooler  (Read 1890 times)
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« on: Dec 29, 2005, 07:29:48 PM »
I am putting a large auto trans 3-core radiator in my '85 this weekend and am curious if anyone has used the trans cooler part of one as a cooler for the power steering?  I'm wondering if the radiator could take the pressure of this p/s pump.  :headscratch:
I have a manual trans and a 3rz conversion (in process) and would like to clean the engine compartment up a bit, and maybe ease up the effort on my steering wheel.  :driving:
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: power steering cooler
« Reply #1 on: Dec 29, 2005, 10:41:52 PM »
I would be more likely to buy a cheapie little auto trans cooler and mount it behind the grill, but that's just me.
  • Administrator
  • Turtle Points: 2243
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #2 on: Dec 29, 2005, 10:49:13 PM »
Hey BUDDERS, check in my project, page 8, reply #309, I used a $23 Auto trans cooler from Summit for my P/S, and its been working out just great-
BUDDERS [OP]
  • Turtle Points: 15
  • Male Posts: 1,335
« Reply #3 on: Dec 29, 2005, 11:29:03 PM »
I checked out those pics Mike.  I guess I forgot to mention that I already have a cheapy cooler from pep boys, but it requires some fabrication of brackets - and I don't have much in the way of fab equipment.  So, I was thinking of taking that back and just using the radiator instead.  Also, do you notice any difference in the steering effort between your truck and say Marlin's?
Shoyrtt
  • Male Posts: 1,294
  • Member since Feb '05
  • VH Runner
« Reply #4 on: Dec 30, 2005, 10:11:22 AM »
I ran a similar set up to Big Mike's on my old Samurai (with Toyota power steering). The trans cooler I used came came with some cheepie mounts and some sort of zip ties that worked well.  :twocents:
http://www.sharetrails.org/
  • Administrator
  • 511:1 Club
« Reply #5 on: Dec 30, 2005, 10:58:10 AM »
hmmmmmm Its very hard to compare my truck with Marlins, especially Marlins, since he has a Hybrid Toyota/D60 front end. Its wider and really different..
My steering works pretty well, I am using a 14" steering wheel also, but sometimes it seems to pulseate while I am going around freeway overpasses with a long continuous corner. I wonder if it is some air pockets somewhere, but my steering fluid level is above normal right now, and slightly leaking out the cap. One thing though, is that I have remounted my cooler since that picture, and I believe the cooler might actually be higher than the pump :ack: !! I need to check that out when I get back home. I have been thinking about that recently........ :nerv:
Also, I have touched the inlet and outlet of the cooler while wheeling, and I cant seem to feel a difference. But, I also dont have a fan shroud, so I dont think much air is being pulled through the cooler, so it is more or less just something for the heat to soak into instead of instantly overheating the fluid.
Yup, once I get en electric fan back in there, I will move the cooler lower and into the air flow.
Ohh the things to do.......
BUDDERS [OP]
  • Turtle Points: 15
  • Male Posts: 1,335
« Reply #6 on: Dec 30, 2005, 06:58:31 PM »
Ok guys.... I did a little reseach today at the shop and found out my 3rz p/s pump can put out 1200psi of fluid.  When compared to around 200psi for trans fluid, I think I will just rig up my cheepo cooler.  I'ts not worth risking bursting a seam in the radiator to contaminate the coolant.
Mike, which electric fan are you going to run?  I have the Black magic setup on my little '87 lowrider and boy does it suck the air.  It's really noisey when it kicks on, but still kind of hard to hear over a mild race engine with a header and all the other squeaks and rattles.  I think for now, I'll stick with the stock 3rz fan for my '85.  After all, I was given a brand new fan clutch for it.
Last post Apr 01, 2004, 12:25:32 PM
by burl4x4
Last post Mar 28, 2004, 12:14:47 PM
by burl4x4
Last post Mar 30, 2005, 07:13:42 PM
by yotaboy79
Last post Jul 11, 2007, 07:34:47 PM
by CRS
Last post Sep 07, 2006, 02:01:33 PM
by Shoyrtt
