Author Topic: important efi information!!!  (Read 7184 times)
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
« on: Dec 23, 2005, 02:01:28 PM »
ok every body, you may or may not have heard that i have been having serious issues with my 22re not running correctly and have spent countless dollars replacing parts that actually did not need to be replaced.
i happen to be related to one of the engineers that helped design 2nd gen trucks and supras ect.
and i had him over at the house yesterday and he informed me that these trucks have problems in the wiring harness that spans from the cab on the drivers side to the ignitor, mass air flow ect, in to the engine bay. seems as though this section of harness is more prone to corrosion than any other parts. sure enough, i removed it and all the tape and there where 6 wires that where badly damaged, the o2 sensor was broken all the way(wire) and the main power supply wire was only holding on by 2 strands of wire, instead of 30 or something.
i reconected all damaged wire and put heat shrink over tham, and wala, the truck runs better now than it ever has, is quieter, smoother, more powereful, and idles at 650 with no shaking as it did before. so--- :think: if you have efi related problems, first thing to do is start shaking harnesses and connectors. toyota says that nearly 3/4 of the efi problems in trucks of this age (80s) can be traced to faulty wires, coroded connections, or poor connections.
hope this helps all in the marlin world :thumbs: --crawlerdan
crawlerdan [OP]
  • Male Posts: 4,770
Re: important efi information!!!
« Reply #1 on: Dec 23, 2005, 08:48:47 PM »
 :thumbs: ill look at the intake side of the harness next if i have to but lets hope that this solved the problems!!
« Last Edit: Dec 23, 2005, 08:53:35 PM by crawlerdan »
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • I named my son Wheeler!!!!
« Reply #2 on: Dec 24, 2005, 07:48:57 PM »
Thats some good info Dan. :thumbs: Mine is/has been running wierd every since I did the efi conv. Sometimes it won't start with the relay in and I have to remove a fuse and stick it back in to get it to start. And it has always had a miss at idle. I'm gonna check the wiring tommorow after dinner!! :beerchug:
www.wheelingarizona.com
  • Turtle Points: 1088
  • Male Posts: 9,757
« Reply #3 on: Dec 24, 2005, 10:21:49 PM »
I sure hope this is only an issue with the first efi setups, not 89 and newer.
toyfamily
  • Member since Dec '05
« Reply #4 on: Dec 24, 2005, 10:37:16 PM »
Did you remove the harness on the driver side and if so how difficult was it to remove?
crawlerdan [OP]
  • Male Posts: 4,770
« Reply #5 on: Dec 24, 2005, 10:37:22 PM »
didnt say, but this is always usefull info!!
crawlerdan [OP]
  • Male Posts: 4,770
« Reply #6 on: Dec 24, 2005, 10:49:21 PM »
i pulled it out and layed it on the tire to work with, whole process took me 2 hours start to test drive!! sooooooooooo worth it :love:
crawlerdan [OP]
  • Male Posts: 4,770
« Reply #7 on: Dec 24, 2005, 10:51:01 PM »
hope you find something that helps out bro--goodluck, happy baby Jesus day--dan
Trunkz
  • Turtle Points: 79
« Reply #8 on: Jan 20, 2006, 04:37:04 PM »
anyone have any pics of where to look for the power supply wire?
got an 87 that this may be an issue with
thanks
Mike
crawlerdan [OP]
  • Male Posts: 4,770
« Reply #9 on: Jan 20, 2006, 06:10:03 PM »
thanks
Mike
look at the loom that is in the drivers front fenderwell, that goes to the mass airflow meter and coil..ect :thumbs:
eightyfive
  • Turtle Points: 232
  • Male Posts: 552
« Reply #10 on: Jan 20, 2006, 08:50:41 PM »
PICTURES!!!!!! please?
1985 TOYOTA 4RUNNER
crawlerdan [OP]
  • Male Posts: 4,770
« Reply #11 on: Jan 20, 2006, 09:16:30 PM »
i donthave pics, but ther is only 1 loom in the drivers fender well, like under neath, by the tire, inbetween the plastic fender liner and inner fender
in there where the arrow points
reklund5
  • Turtle Points: 286
  • Male Posts: 1,263
  • Member since Nov '03
  • I love my Marlin Crawler!
« Reply #12 on: Jan 21, 2006, 07:57:30 PM »
I've also seen the harness rub on the fuel rail on the intake side of the engine, and rub thru the loom, thru the insulation, and let the injector wires/coolant temp sensor wire/etc ground out on the fuel rail.  I've taken to installing a piece of heater hose over that section of fuel rail and making sure the wire loom is in good condition.
Ryan
dentedfender
  • Turtle Points: 85
  • Member since Jul '05
  • Jeep eater
« Reply #13 on: Nov 08, 2007, 06:38:17 PM »
Just found this post, and i think it may be a problem with mine as well.
85 4runner rears up front f-150s out back dual 2.28 cases 22re, rear discs, 5.29s, locked f/r, 38s....... list goes on and on
crawlerdan [OP]
  • Male Posts: 4,770
« Reply #14 on: Nov 08, 2007, 07:01:27 PM »
like i said 2 years ago, if you are having problems with efi stuff, shake connectors near sensors, check grounds, and check for coroded wires
Last post Jan 21, 2005, 04:33:06 PM
by HFCRAOffroading
Last post Jan 26, 2005, 08:34:58 PM
by HFCRAOffroading
Last post Feb 14, 2012, 11:25:43 AM
by rage
Last post Jan 16, 2014, 12:25:06 AM
by Noz
Last post Oct 01, 2014, 02:56:05 PM
by H8PVMNT
