Author Topic: 22R-E Fuel pressure ???  (Read 7276 times)
Fongs
  • Male Posts: 299
  • that`s the way to hell
« on: Nov 26, 2005, 02:27:44 AM »
hey Crawlers :greengrin:
we plane now the engine swap from 18R to 22RE on the Green Can Project
and i have 2 diffrent Informations for the Fuel pressure
from the Fuel-Pump :-\\   :confused:
Fuel pressure: 265–304 kPa
(2.7–3.1 kgf/cm2, 38–44 psi)
or
Fuel pressure: 226–265 kPa
(2.3–2.6 kgf/cm2, 33–37 psi)
which information is correct ???  ???
Thanks :thumbs:
Prismo
  • Online The 1K Club
  • Turtle Points: 7413
  • Member since Oct '03
  • Living in the green house
Re: 22R-E Fuel pressure ???
« Reply #1 on: Nov 26, 2005, 02:33:00 AM »
1990 is 38-44 psi
Uncle Jesse
  • Turtle Points: 21
  • Male Posts: 375
« Reply #2 on: Nov 26, 2005, 09:00:20 AM »
1989 is also 38-44psi this is with the engine off.  Meaning no vacuum to the pressure regulator therefore max fuel pressure.  With the engine running and vacuum to the regulator, the spec is 33-37 psi.
Uncle Jesse
  • Turtle Points: 21
  • Male Posts: 375
« Reply #3 on: Nov 26, 2005, 09:01:45 AM »
BTW, make sure you use a good quality pump, preferebly factory or a factory reman.  Some pumps are physically smaller in size and will have to work harder to keep up with the larger factory size.
Fongs [OP]
  • Male Posts: 299
« Reply #4 on: Nov 27, 2005, 03:05:03 AM »
@Prismo , Uncle Jesse
Thanks   :thumbs:  :thumbs:  :thumbs:
engine swap infos will following... :greengrin:
Last post Apr 20, 2006, 08:04:21 PM
by dieselsmoke
Last post Dec 22, 2006, 10:39:39 AM
by TRHS1980
Last post May 05, 2007, 09:06:20 PM
by brainlessfool
Last post Jul 17, 2007, 11:17:37 AM
by phi564
Last post Apr 30, 2008, 09:32:27 PM
by DontStall Rockcrwl
